Results 1 to 48 of 48
    Jul 2013
    My endless problems with F29 Carbon 1 2013
    Hello guys, here is my list with the problems encountered in no more than 2 months usage:
    1) seat tube crack : F29 Carbon 1 seat tube crack
    2) broken rear hub ?
    Cannondale F29 Carbon 1 Reynolds rear hub - YouTube
    3) chain stuck between bottom bracket and lower chain ring (possible due to point 2 )
    4) oil leak in the lockout area of the Lefty fork
    5) loose spokes
    6) violent vibrations on front braking (due to incorrect brake adapter)
    I'm pretty disappointed with the bike as my previous cheaper RZ 120 XLR1 bike was flawless.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Longtime Cannondale lover myself. But when they went Global Corporate in 2010 and sent mfg to Asia...I got off their ship. There is better brands out there, guys....
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Reputation: StumpyElite2010's Avatar
    Sorry to hear about your F29 failing.
    I have 2011 Flash C2 29 and zero problems here, other than the chain suck, which was a major issue.
    My LBS replaced the crank with XO, the FD with XX under warranty and the problem is gone.
    I am not crazy about the front shifting (My thumbs are sore from the hard friction)
    But overall I love the bike and once the chain suck issue was fixed it never fails me.
    S.C. TB2
    Flash29C2
    Niner One9 SingleSpeed RDO fork
    Supersix Evo 1 Hi Mod D/A
    I haven't had problems with the lockout of my fork. But it did have scratches on the inner leg, and seemed to leak oil. I had the fork sent to Cannondale in Holland. They changed the inner leg, and it's been fine since then.
    As you know, my frame has a similar crack in the seat tube.
    I've heard some bad things about the Reynolds wheelset. Hopefully they'll be fast when repairing your wheels. I have only had loose spokes (going to the LBS tomorrow to have that fixed).
    My chain can also get stuck between the BB and the little chainring, but only if I take the rear wheel off (and put the bike in the car), and I'm not careful about not dropping the chain without the rear wheel. I've never dropped the chain or had chainsuck while riding (and I've ridden the bike quite a lot).
    You definately need to have the wheels fixed, so you can ride. If you can get another wheelset instead, that could be an option? I'd get Enves if I could choose. Same with the fork, that needs to be fixed before riding. You don't want oil on your discs (not very likely, but still).
    My bike also had the wrong front brake adapter. I didn't complain too much about it, but I think I should have. It is dangerous! Besides, I've now changed to 160/140 discs instead. I had problems with the stock pads though, noise and vibration.
    Jul 2013
    The problem with the fork occurred only one time just before first ride, I turned the bike upside down to convert the wheels to tubeless, this could be the explanation.since then I didn't saw any leakage and seems to be okay.
    Regarding the chain stuck it might be related to the problem with the hub, because I recently noticed that for a small amount of time when I pedal in reverse (with might happen when I try to clip back the pedals) the rear cassette gets blocked so the chain could drop in that moment...
    I sent today the email to my LBS, wasn't quite a friendly email, and I'm waiting to see their response and how they want to further proceed.
    Reputation: Flash29r's Avatar
    May 2013
    Well, it really is not the LBS fault that the hub went bad. I have the same wheel set on 12 Flash Carbon 29r and the freehub is fine on it. It just needs a new free hub, not a whole new hub. LBS should be able to replace it for you and may not even have to contact Reynolds on it since it shouldn't really be a Reynolds specific item. Spokes have come loose on mine, but have been fine since I have tightened them up. I would say whoever built the wheels at Reynolds did a poor job. But to be fair spokes can come loose on a new wheels set. Frame crack seems like it is related to the Save seatpost and Cannondale may need to look into that situation. I don't have that post and probably won't see the issue on mine. Chain suck can happen on any bike and is not to be considered a defect. Rough trail, slapping chain while shifting can cause it and if you throw mud into it things get worse.
    Jul 2013
    You're right, isn't the LBS fault for the hub, I just sent them my dissatisfaction regarding the multiple problems that I encountered with the bike, and the last one could prevent me participating to the upcoming races that I already paid for.
    Hopefully would be like you said, only the freehub will need to be replaced.
    The chain stuck indeed can be cause by many things, but in my case it occurred to often and without shifting. I hope to be also related to the hub problem.
    Jul 2013
    Re: My endless problems with F29 Carbon 1 2013
    I need a new free hub, this one looks pretty bad, the guys cleaned up but the clickets (don't know the English word) get stuck and are oxided.
    Now if I talk with my LBS I'm pretty sure that they would only delay me, how Reynolds RAP works? Can I contact them directly, it will work quicker this way?
    Sent from my GT-I9300 using Tapatalk 2
    Attached Thumbnails Attached Thumbnails My endless problems with F29 Carbon 1 2013-uploadfromtaptalk1375118895214.jpg
    May 2013
    I don't think the RAP is in place for hubs, more for the rims themselves. You can try to get them to replace it under that, but you would have had to register your wheels when new. Given how your freehub looks they will not warranty it at all. Looks like it saw serious amounts of water with no maintenance. I'm thinking by looking at that it would fall under neglect. You can try to get them to replace it, but I don't think you will get very far. Just buy a new freehub and ride...
    Jul 2013
    The wheels have no more than 2 months, whatever conditions would have been is not normal in such short time. Also the guys from service told me that the bearings and the rest are perfectly fine so if all these pieces have the same build quality then all of them would be affected the same, which is not the case here
    I would buy myself a free hub but I really don't know where I can find /order such piece..
    Quote Originally Posted by muntos View Post
    It's called Freehub Pawls. Shame on Reynolds!
    May 2013
    http://www.reynoldscycling.com/uploa...1201162428.pdf Use this and see if you can get it cleaned up and useable. It appears to be a DT 240 hub that they use that is made to Reynolds specs. From looking at the PDF it appears to be serviceable.
    We have had at least 5 reynolds freehub failures at my shop alone. One occurred during Pro XC Nats…They've been replacing them but the replacements have also been failing. Luckily no one has gotten hurt yet.
    Jul 2013
    It seems that there is a design flaw with these hubs, my question is, can I replace the freehub with another manufacturer, are any compatible ?
    May 2013
    Quote Originally Posted by Zachariah View Post
    Reynolds doesn't make the hubs, so really not their fault. They are DT hubs with Reynolds name on them.
    May 2013
    Hard to say, would have to be some trial and error. Your LBS would have to help you with that. I don't know how interchangable the freehubs are from one brand to another hub.
    Jul 2013
    My LBS don't know sh**, actually they only sold me the bike and for any problems they told me to contact the local Cannondale dealer. The local dealer is another bad joke...
    Ok, let's say that freehub is hard to match, but how about a whole hub? I didn't see many options for 24 holes hub either...
    May 2013
    They sold you the bike and they are not a Cannondale dealer? So is this a used bike or new? Why don't you try to contact Reynolds and see what they can do for you. Sounds like you have no decent local support what so ever. Beyond that you get another hub laced up to the rim and your done. DT is the maker of the hubs from what I can find out, but since they were done for Reynolds you may have to go through them.
    May 2013
    Here you go: DT Swiss 180/240/350 Freehub Body at WesternBikeworks Seems like it is a direct replacement, but I am not a 100% positive. You may have to contact them before purchase.
    May 2013
    Ok, just found this: Excel Sports: Servicing a DT Freehub body - YouTube If these are indeed DT hubs they seem simple as hell to service. Probably not the body at all but the star gears just need a good cleaning and lube. Watch it and perform the maintenance to see how it works for your. OP, yours looks like it just needs a good cleaning.
    Jul 2013
    The shop that sold me the bike is in another town and they are some sort of Cannondale re-seller. The bike is new.
    I have sent to Reynolds an email, I'm waiting for a reply.
    Jul 2013
    It would be simple if the hub is this, but it is totally different, the powls are attached to a spring, and even if the guy from service tried to clean and lube them very very good they still get blocked because the spring seems to lost its tension power.
    Sent from my GT-I9300 using Tapatalk 4 Beta
    Hmmmmm. Maybe I should see what my freehub looks like....
    EDIT: How is it removed?
    Jul 2013
    Yes, it would be a good idea to check it, because it seems is a problem with the 2013 wheels design.
    Love'm - Hate'm Reynolds 29er Carbon Wheelset
    How did you remove the freehub?
    Jul 2013
    Oh, I didn't, the guys from the service did it, I don't have the proper tools for this and also it didn't seemed an easy job...
    I see. This really sucks. I have heard some pops from the freehub when accelerating. My LBS says I shouldn't worry. But when people have had problems with them I start to worry. They are my only wheelset, and I won't be able to afford another wheelset this season. If they break, the season ends for me.
    Jul 2013
    Yes, same for me, my advice would be to take them to your LBS, remove the hub, and clean the internals. At least this operation only could help and prevent the premature wear.
    Jan 2014
    Hi everybody,
    I am planning to buy a Cannondale with this set of wheels. Did Reynolds finally fix your problems by changing the whole rear hub and new spec spokes??
    Thank you for your help!!
    Jan 2014
    Nobody???
    May 2013
    Quote Originally Posted by Asterixx View Post
    Hi everybody,
    Who is your question directed at? If you have any problems with the wheels when you get them Reynolds has excellent CS at least here in the states they do. I don't know how things are handled if you are over seas. I know they took care of my issues and it was very cheap to do so.
    '12 Flash 29r C3 with a few mods
    '10 Synapse 5 Carbon with a few mods as well..
    Jul 2013
    I didn't had problems with the spokes and replaced only the freehub,no problems until now but I have no doubt that Reynolds will replace the whole hub if I will keep having problems
    Sent from my GT-I9505 using Tapatalk 4
    Sweater
    Reputation: Buzzaro's Avatar
    If the oil was leaking from the damper, you would see it at the bottom of the fork as well during normal use. There is grease used to lube the non-damping sliding parts inside the body of the fork and what you saw was probably some of that. Unless you see a higher volume that will coat a good portion of the outside of the fork, you should be fine.
    Also, it's a 5 minute deal to remove the damper and check it out. Super easy, two steps more than a bearing reset. Just remember to release the air spring pressure.
    All out of S**** and down to my last F***
    Jan 2014
    I am living in the UK. I hope CS to be as good as the one in the states... I will probably buy the bike, and the wheels look awesome and don't seem to have problems after reynolds' hub change and spoke retensioning...they seem to offer a quick service too!!
    Sweater
    Quote Originally Posted by Flash29r View Post
    That photo doesn't look like a DT 240 or similar. DT's use a star ratchet and that looks like standard type pawls in his photo.
    That hub pictured on page one does not look like a dt 240. Dont think that hub even has "pawls".
    Reputation: ChiRho's Avatar
    Aug 2005
    That's exactly how my DT Swiss 240s hub is configured. The 2 piece star ratchet engages the teeth in that free hub as shown.
    Support your Local Coffee Roaster
    Sorry but that free hub has pawls. 240s use start ratchet.
    Jan 2014
    And with the new reynolds replacement hub, the free hub continues skidding or not? It is dangerous, i had a nice crash because of that with a shimano worn hub...
    Aug 2005
    I don't see any pawls in that linked photo, but suit yourself. Take yours apart and see. I service those hubs all the time............ This vid will show the same free hub body as in the linked photo if you watch till the end.
    I cant qoute with the pic from my phone but, look ar post #8 an tell me that free hub doesnt have pawls. There is a chance we are talking about different post #.
    Aug 2005
    Ha, you're right, we were looking at different posts/pictures! I was looking at the link just a few posts above that showed the DT Swiss free hub body. Sorry for the confusion!!
    But whats weird is thats the free ub that the original poster pulled out of his renyolds wheel.....I think.
    Sweater
    Quote Originally Posted by ChiRho View Post
    Yes, sorry I quoted the link. Which is a DT freehub body. I was talking about the OP's photo from post #9. It looks like a standard pawl setup.
    Aug 2005
    Yeah, I agree, I didn't know quite what to make of that picture in the original post with how bad it looked. I think the hub pictured in the OP is this one by Reynolds?
    in Bellingham, Washington, United States - photo by mikekazimer - Pinkbike
    Jul 2013
    Yes, it was my Reynolds freehub after 2-3 months of use..
    Jul 2013
    Hat down to Reynolds! Best customer service ever! After receiving the freehub, now I got an entire new redesigned hub, new spokes and nippels after only 6 days since I wrote them.
    For sure they won a loial customer!
    Same here. I quite like Reynolds
  1. 2013 Specialized S-works EVO Boa problems?
    By redmr2_man in forum Apparel and Protection
    Last Post: 07-09-2013, 01:48 PM
  2. 2013 slayer ss problems
    By CRFer in forum Rocky Mountain
    Last Post: 03-08-2013, 09:06 PM
  3. 2013 rm slayer ss problems
    By CRFer in forum Urban/DJ/Park
    Last Post: 02-14-2013, 11:16 PM
  4. 2013 Rockshox SID XX Solo Air Problems - Need Help!
    By Abras in forum Shocks and Suspension
    Last Post: 01-31-2013, 04:30 AM
  5. Replies: 4
    Last Post: 08-16-2011, 01:19 PM
