Results 1 to 3 of 3
    Bike to the Bone...
    Reputation: rzozaya1969's Avatar
    Minimum insert point on F7 seatpost
    My seatpost has some vertical lines rather than a single horizontal line to indicate the minimum insertion point. Can I still use the seat as long as some part of the lines are inside the frame, or should when the lines start to appear on the seatpost be the don't raise the seatpost point?
    Thanks.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    To be safe, I'd say the top of those lines but also make sure the seatpost is inserted so that it's end is below the top tube...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    I agree with Dan. Keep the seatpost bellow the top tube, even if it's still above the line on the tube. Every frame model is a little different. It's way better to get a seatpost that works for you than have to shell out $$$$$$$$$$$$$$$$ to replace your broken frame
    Lead by my Lefty............... right down the trail, no brakes.
