Results 1 to 7 of 7
    A little of everything
    Reputation: Anders's Avatar
    Making a Lefty Ultra PBR work on a Flash
    I can get a good deal on a Lefty Ultra PBR. I have a few questions in relation to using this on my Flash frame as an alternative to a Lefty Speed PBR.
    Does this fork have the same A-C measurement as a Lefty Speed PBR?
    Are there any difference in suspension feel, damping and lockout between the two?
    Do I need to reduce the travel and will it make a difference to how it rides?
    Jun 2010
    Flash manual says that max fork length is 500mm, Ultra is for sure more... so, the answer is no.
    The Ultra is 490mm, så I guess that's not an issue then.
    I just bought a 2010 Flash frame and put on the parts from my 2009 Scalpel including a Lefty Terralogic (A-C 480mm), which I'm about to sell. So I'm looking for a new fork.
    Originally this Flash came with the Speed Carbon DLR (A-C 485mm). Looking at the specifications for the new Speed PBR/XLR the A-C is only 470mm on these. I feel the bike is already very sensitive in the steering and putting a new Speed PBR or XLR on it would make it even "worse".
    That's where my idea for the Utra with an A-C of 490mm came into the picture. I guess it could be tuned with a small spacer at the upper air seal if I find it too tall, a spacer to reduce the travel if at all needed and some volume reducers if it's too linear for the Flash.
    I know it may seem like a lot of hassle, but I guess there is no other way to get a PBR or XLR with an A-C of 480-490mm.
    Lefty Experts, does this give sense or am I missing some important facts?
    Jun 2010
    Quote Originally Posted by Anders View Post
    note that I wrote "max fork length is 500mm", A-C is another.
    In theory you are right as Cannondale specify fork length as the A-C length plus the height of the lower headset cup. But in my case as the Flash doesn't have one they are equal.
    Reference: http://cdn.cannondale.com/Manuals/20...echnote_en.pdf
    Not dead yet, just playin
    Reputation: ohpossum's Avatar
    FWIW, I think the A-C of the Speed DLR is closer to 480mm.. Personally, I wouldn't worry about the extra 10mm A-C. You might like the way it slows the steering down a little.
    Though I haven't done it yet, I also plan to add a 10mm spacer to the upper air seal to use a 120/140 PBR damper (Red) in a 110mm DLR.
    www.msmtb.org - Mississippi Mountain Biking
