Results 1 to 5 of 5
    New question here. Lowering the bars on a Trail SL 29ss
    I have a Trail SL 29er SS (the white 1), as well as a flash alloy 29er.
    I would like to lower the bars on the SS a bit, due to my body shape the saddle and bars as current almost level an i would like to drop the bars about 20to 30 mm. The headset has a cone spacer/top cap, I and looking for suggestion on swapping this out with a flat style cap and an extra spacer or 2 to give me some room for adjustment. Any pics or suggestions appreciated.
    And yes, I am still using the original fatty fork.
    Thanks all
    Andy (Ozbikebuddy)
    29er you just know when ur ready!!!!
    Reputation: ascoda's Avatar
    Oct 2011
    Mine came with a 7 degree up swept stem. If yours is the same, flip it. You could also remove a couple of the spacers, and maybe get what you want without swapping any parts.
    Ascoda, yeah went there too. I have already flipped the stem but the two spacers are only 5mm and I would like to go another 20mm or so lower
    Never trust a fart
    Reputation: frdfandc's Avatar
    Your probably going to have to run either a high rise stem, something int he 17 degree flipped down and/or the handlebar upside down to drop another 20mm.
    Upside-down riserhandlebars. Short persons on 36ers, 29ers and 32ers
    There is a cone spacer above the headset, i am going to see if i can drop that out and get another top cap to go in its place
  1. shortening stem and lowering handle bars?
    By Smilerz in forum 29er Bikes
    Last Post: 02-22-2013, 07:01 AM
  2. Thoughts on 26ss vs 29ss
    By kikoraa in forum Singlespeed
    Last Post: 12-10-2012, 06:33 PM
  3. XTR Trail levers going to the bars after a rain race
    By broadwayline in forum Brake Time
    Last Post: 08-10-2012, 11:28 AM
  4. Comparing my 29SS to my 26HT
    By skankingbiker in forum Singlespeed
    Last Post: 05-17-2011, 08:29 AM
  5. 2011 Trail SL3 29SS
    By poorboy006 in forum 29er Bikes
    Last Post: 01-07-2011, 08:14 AM
