Results 1 to 9 of 9
    Lockout not working.
    2008 F4. I noticed today my lockout lever doesn't do anything. Not sure where to start. I might be overlooking something simple or may need to go to the local store.
    Any ideas or things to look for?
    2008 Cannondale F4
    Shimano XT brakes, ice tech rotors.
    Maybe Mendon will chime in here with some technical advice you can try, but I would suggest to bring it into a dealer. This happened to my lefty and the seals had to be replaced.
    Quote Originally Posted by OLx6 View Post
    thanks.
    Do you mind me asking roughly what the cost for your repair was?
    I guess I can call my lbs store but I doubt they'd even give me any ideas. They are always at least 2 weeks out for any work also.
    2008 Cannondale F4
    Sorry I can't remember the cost, because it was still under warranty.
    Dec 2012
    If lockout is not working it usually means that damper has lost quite a bit of oil so it has to be topped up and probably seals to be replaced. But don't be surprised if it starts to leak again
    Feb 2005
    Sounds like service time.
    As others have said, loss of oil makes it not work. If it's never been serviced since new, you're way past time.
    Cannondale recommends annual service. I often say you can stretch it to two years if it;s not ridden really hard, but still, time for some lovin'....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Dropped it off today. They think the seals can be replaced but will call me when they get into it.
    Hopefully it's a reasonably easy fix.
    I really need to learn to do the basic maintenance on it.
    Where's the best place to learn. I could come here and ask questions but it seems like most members have higher end models which probably have alot of differences.
    2008 Cannondale F4
    Lbs says cannondale doesn't make a repair kit for my bike since it's older. He said they did put air in it and it's holding.
    What are my options to replacing it?
    2008 Cannondale F4
    Feb 2005
    Actually, they do offer all the seals required, unless you need a complete damper, which, unless the shop screwed it up trying to *fix* it, you shouldn't by any means need.
    Sounds like a shop that just doesn't know what they are dealing with.
    Find someone who does, it'll be far cheaper than replacing it, I guarantee it.
    - FrostyStruthers
  1. Lockout not working
    By detoxdiet in forum Shocks and Suspension
    Last Post: 08-17-2014, 02:29 PM
  2. I had to do this to get the lockout working...09 reba
    By SEvEnDuSt717 in forum Shocks and Suspension
    Last Post: 09-11-2012, 08:51 AM
  3. Fox Lockout No Longer Working
    By Toff in forum Shocks and Suspension
    Last Post: 07-26-2012, 06:53 AM
  4. Fox lockout/ProPedal....working?
    By tjwil9488 in forum Shocks and Suspension
    Last Post: 04-28-2012, 08:58 PM
  5. Tora TK lockout not working?
    By SgtBaxter in forum Shocks and Suspension
    Last Post: 11-08-2011, 03:01 PM
