• 12-17-2012
    rcruz2525
    Light and comfortable saddle for flash
    Hi, I finally decided to build a new Cannondale Flash 29er.
    Coming from a Specialize full suspension, I think the change will be a bit drastic for me, so I am trying to make the ride as comfortable as possible and I am looking for a light but comfortable saddle.
    I know there are a lot of different ones and would like to know what you guys use.
  • 12-17-2012
    rcruz2525
    I was looking at:
    - Sella Italia SLR Flow
    - Fizik Tundra 2
    - S Works Toupe
    Are this any good, what is better as far a confer and light weight
  • 12-18-2012
    BoostN7
    Hey mate,
    The Flash 29er is noticeably stiffer than most hard tails, let alone a squishy full-sus, but you should be alright. It's a 29er, so more comfortable than it's 26" counterpart. If I was you, I'd go to a bike shop and have a bike fit to get the right saddle. I run a Tundra 2 (which I'm going to replace), but it's too narrow for me, which means I don't really "lock in" to my bike and I get a lot of movement in my lower back, which leads to back pain. I' working on improving my flexibility, which will make it better, but it still won't be right for me. It's not like a can shrink the size of my pelvic lol!
    One saddle that suites most is the Fizik Gobi. Might be worth a shot. I'd go for something that's comfy over something that's light weight if I were you. You won't notice the weight difference when you can't ride your bike because you've got back ache. Trust me, I know.
  • 12-18-2012
    58teeth
    I have a Phenom, which is the MTB version of the toupe (slightly different cut), but recently switched to the Henge. I've ridden the Toupe religiously on my road bike for years, but found the rather rounded nose to be a little uncomfortable on the dirt with the Phenom. The Henge has a flatter nose, pain relief channel like the Phenom (no cut out) and I find it's a much "grippier" saddle as well.
  • 12-18-2012
    rcruz2525
    BoostN7, I agree with you on the comfort vs light.
    I am going to a hard tail and have several friends of mine doing the same, one of them just built a HT Sette, he is using a Fizik Tundra 2, and after his first ride his back was hurting for 3 days. Now, I am not blaming the saddle but I am sure a comfortable saddle is a must to have.
    I will look into the Fizik Gobi and the Henge.
  • 12-18-2012
    BoostN7
    I have to stretch my back out before and after a ride, if not I pay the price.
  • 12-18-2012
    parkincake
    if your back is hurting after a ride it's more likely a set up issue - the saddle is too high in relation to the handlebar maybe. if your arse is hurting then yeah it's probably the saddle.
    whatever saddle you buy, you're going to need time to get used to it.
  • 12-18-2012
    StumpyElite2010
    +1
    My 2011 Scalpel C2 came std with the Prologo Nago Evo X10 CrMo - 262 gr
    It is comfortable - I like it a lot - never had any issues with it MTB.
    It is semi round, so the weight is distributed between the sit-bones and soft tissues.
    I tried using it on my road bike and my private parts just got numb after a couple of hours riding...
    Not an issue with MTB as you stand on the paddles most of the time... moreover with a racy HT like the Flash.
  • 12-18-2012
    rcruz2525
    I hear you, that is why I want to get information on to what would be a good choice, leaning to more comfort than weight at this point.,.
  • 12-18-2012
    Stumpjumpy
    Selle San Marco Aspide carbon FX. 125g of beautiful sweet comfort. There are few things so light and so pretty that feel so good.
  • 12-18-2012
    Devastazione
    My pics in order :
    1) Specialized Henge,feels like a freaking couch from day one.
    2) Prologo Nago EVO X8
    3) Fizik Gobi XM
    4) Specialized Phenom
    Honestly you can't go wrong with any Specialized saddle.
  • 12-18-2012
    StumpyElite2010
    I have an issue with MTB split tail saddle design.
    Either my shorts or shirt/Jersey get stuck in it when going back from "behind the saddle crouch" position to a normal one.
    I had the old style phenom and it was an issue, so I got rid of it quickly.
  • 12-18-2012
    rcruz2525
    I have decided to go to a bike shop to see what type of saddle is my size. I discover that I need a 155 mm, I can use a 142 but 155 would be better, I think I'm going with the specialize as they have my size and will try the Henge and see how it goes
  • 12-19-2012
    BoostN7
    I'm in desperate need of a bike fit, but I can't afford it atm with Christmas coming.
  • 12-19-2012
    Devastazione
    You can't go wrong with an Henge. We're actually all different and a saddle that feels like a couch for me may feel like sitting on spike for others, from my experience Specialized address the problem 99% of the times :thumbsup:
  • 12-19-2012
    eliflap
    in this topic you are talking about comfortable saddle.
    "light" means another saddles ...
  • 12-19-2012
    rcruz2525
    Well, I think I rather start with a comfort saddle and went I get use to the HT move to a light one
  • 12-19-2012
    A-Ray
    Prologo Vertigo (most comfortable I have ever had)
    Specialized Henge
    Bontrager Evoke
  • 12-19-2012
    limba
    The SLR saddles that say 135g are actually about 7-10 grams heavier. I have two. They weigh 142 and 143. If you're trying to build a light bike, get a scale and weigh everything yourself. Don't trust manufacturers claimed weights.
  • 12-19-2012
    allezdude
    use 1 that worked before
    why not use the same saddle that was on your full squish that you got rid of? of course i'm assuming you liked it. "if it aint't broke don;t fix it" unless you go to a shop that has demo saddles you could spend hundreds trying to find a saddle that's comfy.
  • 12-19-2012
    Flying_Scotsman
    I have a charge spoon on my flash 25, cheapest saddle I have bought in years and by far the comfiest I have ever had!!
  • 12-19-2012
    Bird
    For lightweight comfort...Fizik Tundra 2
    For ultimate comfort and not to heavy...Bontrager Evoke RL
    WTB's pure V and Rocket V felt good too but heavy for the weight consious.
    Saddle choices can literally be a pain in the arse simply because my recommendations may be totally opposite of what you like.
    Most quality bike shops have you sit on a bench to help determine which saddle best suits you "sit bones".
    If you lived in VA you could try the 50 saddles i have in the basement.lol
  • 12-19-2012
    leoferus
    I loved the Prologo X8 that came with my F29. Unfortunately, my clydesdaleism and a crash broke it. I replaced it with a spare Tundra 2 that a friend had laying around. Call me crazy but I love it. It doesn't seem like it should be but it's amazingly comfortable. It is outstanding when pedaling uphill.
  • 12-20-2012
    Bird
    Ok...your crazy.lol
    Actually i thought the very same thing,surprisingly comfortable for a race saddle.
  • 12-20-2012
    elgatovolador
    Totally depends on the shape of your turd-cutter.
    I happen to think the Selle Italia Flite Gel Flow from the 90s is the best saddle ever, for both mountain and road. However, I have Fizik Aliante on my road bike right now, which is acceptable, and Fizik Nisene on my fixie commuter. Works great.
    Hail to the king, baby:
