Results 1 to 7 of 7
    Music & Bikes
    Reputation: fokof's Avatar
    Lefty wheel dish
    Check through the stickies and couldn't find any info : How do you guys check the dish of the Lefty wheels ?
    Can't figure it out ...
    no axe = dish tool= no no
    "There is a big difference between kneeling down and bending over" -FZ
    Nov 2006
    You can use to true, build and dish the wheel, but do not try to ride with it on a regular fork.
    http://www.prowheelbuilder.com/canno...g-adapter.html
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    Music & Bikes
    Thanx for these
    If it's possible for you guys , what's the exact distance it adds on each side ?
    I just have one wheel to check , wouldn't want to pay+-25$ just for that.
    Ridin' dirty!
    I measured the following:
    -Disc side 14mm,
    - 20.4mm on the other.
    Hope this helps.
    You can also get some info at: http://www.prowheelbuilder.com/spokelengthcalculator/
    I just center the rim on the hub (not the flanges). If you don't have a centering gage on your truing stand, just flip the wheel and adjust for the same offset on both sides.
    Music & Bikes
    Quote Originally Posted by cdalemaniac
    -Disc side 14mm,
    Hope this helps.
