Results 1 to 12 of 12
    Lefty Straight Pull Hub?
    Bit of a long shot, but does anybody know of a Lefty hub that uses straight pull spokes in 24h?!
    I have some Easton carbon wheels but want to put them on the Dale so need a straight pull hub.
    Any suggestions much appreciated!
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    The Extralite HyperLefty comes to mind, as a bonus, it's one of the lightest Lefty hub on the market.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    That does look nice but doesn't seem to be much else on the market. Extralite may be the one then!
    Reputation: tomacropod's Avatar
    Why does your rim care if the hub is straight pull or not?
    - Joel
    Cycling is Serious Business.
    Feb 2010
    You won't need a straight pull hub unless you're trying to re-use your spokes. It will be unlikely that you can get a straight pull 24h hub that will have the same dimensions as your easton hub, so spoke re-use is probably not going to happen.
    Circus Monkey do a 24h left hub in alloy and alloy/carbon.
    The Easton rims use a double threaded nipple so the spoke has to be able to turn in the hub to tension them up. Its the rim/nipple design which means I have to use a straight pull hub.
    Reputation: Flash29r's Avatar
    May 2013
    Reynolds has a 24 hole straight pull hub also. I don't know if they sell them separately though.
    Quote Originally Posted by MavAndy View Post
    at $270 you'd be close to making a wheel from a Project 321 hub, DT swiss super comps and a WTB I23 rim.
    Mine was $305 built up
    Lead by my Lefty............... right down the trail, no brakes.
    I did see that but I have not seen any Reynolds ones separately. Maybe its time to sell the Easton's and buy something else!
    Honestly, the only reason I'd keep the Eastons is if they were their carbon rims. Easton carbon has near magic properties.
    They are carbon EC90's hence wanting to keep them!
    Shimano makes a 24h straight pull hub for their lefty wheelset.
  1. DT 240 Straight Pull
    By BJF in forum Wheels and Tires
    Last Post: 09-29-2012, 06:36 AM
  2. Hope Hoops Straight pull 29er bling
    By JMCCRNA in forum 29er Components
    Last Post: 06-01-2012, 12:56 PM
  3. availability of Straight-pull spokes vs. j-bend???
    By Mowerman in forum Wheels and Tires
    Last Post: 05-02-2012, 01:21 PM
  4. Will never buy another straight-pull wheelset again!
    By BaeckerX1 in forum Colorado - Front Range
    Last Post: 06-02-2011, 06:12 AM
  5. Straight pull VS. traditional J spokes
    By Tips-Up in forum Wheels and Tires
    Last Post: 04-11-2011, 08:29 PM
