Results 1 to 7 of 7
    Reputation: beecrazy's Avatar
    Lefty and Stem Length Question
    Hello Folks
    I am looking for info on what is the shortest stem to use with a Lefty fork.
    A buddy of mine purchased a 2006ish F800 (DLR2 fork) and the cockpit is a little large for him, and a shorter stem is in order. I believe the bike has 120 mm stem on it.
    What stem can be used with 31.8 bars before it interferes with the Lefty fork?
    Thank you in advance!
    Don
    09 Specialized Rockhopper Comp 29er
    16 Rocky Mountain Blizzard -30
    Mar 2012
    Well on my 2012 flash 29er I was able to put a 90mm on it but then it made the bike twitchy so I went back to the stock 110mm
    90mm is shortest you can effectively use.
    Thank you Matt116 and Cad10, that will be very helpful!
    I will let him know, and to order one up!
    MTBR to the rescue!!
    Don
    You are very welcome sir
    I have a 90mm on my Rize, with carbon lefty and 31.8 bar and have plenty of room. I don't see why even a 70mm would be an issue...
    As far as I know 90 mm is shortest they make in the OPI stem. Not sure about the other one
  1. Lefty and stem length?
    By rasse1977 in forum Cannondale
    Last Post: 11-26-2012, 11:53 AM
  2. Stem length question
    By MinskyBA in forum Ibis
    Last Post: 10-19-2012, 01:31 PM
  3. Minimum stem length for Lefty Carbon SL 29er?
    By DFYFZX in forum Cannondale
    Last Post: 06-03-2012, 01:31 PM
  4. Stem length and tire question...
    By blaker1983 in forum Beginner's Corner
    Last Post: 05-06-2012, 06:58 PM
  5. Stem length question...
    By xxbrittonxx in forum Beginner's Corner
    Last Post: 02-25-2011, 09:46 AM
