Results 1 to 28 of 28
    YB1
    YB1 is offline
    Lefty Steerer tube for 1 1/8th stems
    I've seen pictures of these here but does anyone know of a production part or a way to actually BUY such a thing? I'm asking because I think at least -10 degree is going to be neccessary on my Flash 29'er and Cannondale doesn't make that. FRM stem will probably do the trick on a stock Cannondale steerer but just in case it would be nice to know of other options...
    Emory Kalahari Kruiser
    Fixin' shocks Day & Night
    Reputation: two6labs's Avatar
    Nov 2008
    Check out 321products... They will be accommodate your needs.
    Tim
    YB1
    YB1 is offline
    Don't they just make 1 1/8th steerers? What I'm looking for is 1.5 Cannondale standard tube with a taper down to 1 1/8th at the top for aftermarket stems.
    The only ones I've seen on this forum are custom... Eliflap's, Mattias, etc.
    Perhaps one of them could hook you up.
    Quote Originally Posted by YB1
    Reputation: XgreygOOse's Avatar
    Speak to Mattias Has anyone spoken to Mattias recently?
    He will hook you up. I've ordered a Lefty Steerer which is made from UD carbon with Ano green parts. Usually takes between 5-6 weeks. I guess he's a very busy man but I know it's worth the wait.
    White is not a colour
    Kam
    Kam is offline
    A hopped on pop.
    Reputation: Kam's Avatar
    project 321 should have a tapered steerer out or coming out VERY soon. email jake at p321 or you can send him a pm, he goes by pumpkinbiter here on mtbr.
    very cool guy/company and good service. they do all the machining in house, so he can give you a VERY good idea on when the tapered steerer is going to be out.
    i am looking at buying one if i build a 1x10 santa cruz tallboy with a lefty pbr. the tallboy uses a "mixed" headset with a 1.5" external lower headset and a 1 1/8" inset upper race.
    cheers.
    "forget kings...forget hadleys......they all have crap engagement. just run your bike fixed gear." - FoShizzle
    (he thinks he can)
    so from what i'm hearing.. project 321 is going to make an adaptor for 1.5- 1.25 headtube's! that'd be awesome for people running tapered.
    I was thinking you could just run the 1.25 adaptor with a reducer (like cane creek's) on the bottom and a normal 1.25 headset with the lefty adaptor to solver your problems..but i could be wrong
    A yeti asr5c would be nice with a lefty
    08 SS c'dale f4
    07 Prophet
    10 Yeti DJ
    Yeti Arc-x
    11 Yeti asr5-c
    ..and they place nice together!
    Reputation: pumpkinbiter's Avatar
    Jun 2005
    I think I saw exactly what your talking about at the Thompson booth at I-bike last year.
    I forgot about it since I haven't heard or seen of it since. You may give them a call and see what ever came of that. We don't make anything like that now. You can always get
    the adpaters for a 1.125 headset and use our 1.125" lefty adapter.
    Jun 2005
    Quote Originally Posted by krismac
    It's true! Should be available next month. E-mail me and I'll put you on a list so you will be notified when they are ready. Jake - Project321
    Mr. Knowitall
    Reputation: hssp's Avatar
    This sounds nice. I am going to go lefty for my next build (unfortunately Cannondale doesn't have the type of bike I am looking for). And now more and more bikes come with the tapered HT, so this I will follow.
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    but do you need a Cannondale bearings perfect fitting tube as mine ?
    with a 1 and 1/8 top tube ?
    Attached Thumbnails Attached Thumbnails Lefty Steerer tube for 1 1/8th stems-hpim0090.jpg
    YB1
    YB1 is offline
    Quote Originally Posted by eliflap
    Yes, I may need that. Do you want to provide it? And if you do, how would you?
    Quote Originally Posted by Kam
    Looking to get a tallboy and project321 adapter too. Is it fine to use my 80mm fork with the tallboy, because they recommend 100mm?
    FIRENZE rulez !!
    installed on Flash 29er
    Attached Thumbnails Attached Thumbnails Lefty Steerer tube for 1 1/8th stems-hpim0291.jpg
    Lefty Steerer tube for 1 1/8th stems-hpim0295.jpg
    Reputation: nathanbal's Avatar
    eli - did you make that yourself?
    Reputation: steph26ne's Avatar
    I need one. Where can I buy it ;-)
    Hello Eliflap,
    I am searching for a tube just like that, where could i get it from ?(i live in the Netherlands)
    Xc rider
    Hi,
    I'm also very interested in one. Where can I bye one and whats the cost?
    GTaholic
    Experimental Prototype
    I'm interested in your steerer tube if you want to sell it? Or else, do you know where to bye one and at what cost?
    Eli,
    I would also be interested in the steerer you showed in this thread...
    Can you help me get one?
    Oct 2010
    MCFK is having one also in the coming weeks.
    Does anyone know if these steerers (MCFK in particular) come with a starnut or expander wedge, or would I need to figure that out on my own?
    FIRENZE rulez !!
    Quote Originally Posted by dwaharvey View Post
    cannondale frames do not need starnut or expander
    carbon tubes too .
    But I mean for using the MCFK carbon steerer (tapered 1.5" -> 1.125") with a Lefty on a non-cannondale frame... surely the requires some sort of expander to adjust the headset...
    GTaholic
    FIRENZE rulez !!
    i used a Mattias carbon tube on a tapered frame from China , LTK 023 29er
    no expander requider
    only a headset press to preload headset bearings
    I feel like not using an expander would be a fringe approach for a normal fork (headset likely to loose adjustment during a ride at some point). Is it just that with the Lefty clamps in addition to the stem clamps that the headset adjustment is more stable?
    I have another related question: I'm looking at ways to get my position as low as I need, and one that came up is to use a Tall Lefty (6.5" clamp spacing) and place the stem underneath the upper clamp. That would allow me to run an effective stack height of 128mm (headtube + headset) rather than 150mm for the standard lefty. But in so doing the upper lefty clamp becomes quite far above the upper headset bearing, and I'm wondering if this is likely to put too much stress on the steerer tube? What do you guys think, is this is a bad idea?
