Results 1 to 8 of 8
    Killer of Chains
    Lefty spring dimensions
    I was wondering if anyone would have a Lefty spring laying around, and if they could measure how long and what diameter they were.
    Just interested...
    RLM
    RLM is offline
    Dec 2005
    DLR2 Green -
    About 110mm long
    About 22mm OD
    Rider of Gnarl
    Reputation: GnarlRider's Avatar
    They vary in size based upon weight (color) -- my black spring is an inch longer than my green spring
    Feb 2005
    Which spring? DLR top out? DLR2 negative? Max, steel, ti? And as mentioned, there are differeing lengths based on rate, and travel (130, 140) Rock out
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Killer of Chains
    Lefty Max Brown Spring?
    I may have sourced a cheaper, stiffer solution.
    Killer of Chains
    Actually I need the internal diameter more so than the external.
    But both would help.
    Feb 2007
    "I may have sourced a cheaper, stiffer solution"
    I'd be interested to learn what it is.
    Feb 2005
    Quote Originally Posted by PaintPeelinPbody
    All I got... Sorry it got a bit convoluted, just follow in straight lines, but it doesn't seem to have what you want....
    Lefty Max 140
    Material Steel
    Spring Color Rate (lbs/in) Bottom Load (lbs) Length Travel (mm) Weight (g) Spring Spacer (mm) Travel Spacer (mm) # Bumpers
    Soft Green 41 226 225.5 140 156 NA 17 1
    Standard Blue 50 276 228.8 140 174 NA 17 1
    Firm Red 59 325 235.7 140 197 NA 17 1
    X-Firm Black 68 375 244.4 140 253 NA 17 1
    XX-Firm Brown 77 424 254.8 140 262 NA 17 1
    - FrostyStruthers
