Results 1 to 2 of 2
    New question here. Lefty Speed Bonded DLR2 on jekyll 700?
    I got a question from a guy on eBay (http://cgi.ebay.fr/ws/eBayISAPI.dll?...m=200224958330) but I ignore the answer so I turn to you, subject matter experts.
    this guy would like to install a lefty speed bonded DLR2 on Jekyll 700. Is this feasable?
    He also runs Cross Max rim.
    Thanks for your help
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    It is possible. Depending on the model year of the Jekyll though, it might change the geometry a bit. Some early Jekylls had Headshoks which have about the same height as a Lefty Speed but later models had longer Lefty Max that were taller. Regardless of the year, a Speed Bonded DLR2 will work and given that the Jekyll has adjustable geometry, it will probably be possible to make the lower front end managable if it was build around a later, taller fork.
    As for the Crossmax, as long as his front wheel is Lefty specific, it will work on the DLR2.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
