Results 1 to 3 of 3
    Mr. Knowitall
    Reputation: hssp's Avatar
    Bonking ... not feelin' well Lefty spacer and P321 hub
    Do I need the spacer covering the big bearing on my P321 hub? Just got my wheel from my local builder, and I got to think of it. I have only one, and I have no time during business hours to pick up one from my LBS. This is a bit urgent, so I hope it is no biggie. The hub is delivered with Enduro ABEC 5 bearing if that has something to say...
    Please help
    Reputation: brentos's Avatar
    Jake @ P321 feels the extra bearing schield is unnecesary with the Enduro bearings installed in the P321 hubs.
    Be sure to remove or grease the rubber seal around the hub fastening bolt on the drive side of the hub as well..or else it will sqeak, loudly. I removed mine and put some extra greas in around the bolt head to resist water intrusion. Less resistance this way.
    Mr. Knowitall
    Thanks brentos. I have already added grease to the bolt, as my other wheel started to squeek I am soon ready to go now! Yeti 575 with Fox RLC Lefty Max!
