Results 1 to 5 of 5
    im your designer tonight!
    Reputation: rappid's Avatar
    Lefty small movement
    Hi,
    Bought Flash hi mod 1 2010 with lefty speed carbon DLR SL few days ago.
    I have noticed some small movement (up and down) when the lockout is on.
    This I was told by the shop is normal but I want to hear something from you.
    Thanks for any help.
    cheers, rappid
    JNG
    JNG is offline
    Oct 2011
    Normal. My Lefty Speed PBR does that too. Nothing to worry about.
    Feb 2005
    Not so much normal, but not dangerous, or an indication or imminent failure, or internal damage.
    The lock out works on the principal of oil being non compressive. Air, does compress.
    So, you have a bit of air in the damper. As long as t doesn't increase rapidly, I'd not lose a minutes sleep over it. If you see more "travel" over the course of a few days or weeks, time to get a tech in there to check damper caps for proper tightness, and refill/bleed the damper.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    thanks lads!
    cheers, rappid
    Reputation: lesper4's Avatar
    Mine moves quite a bit the shop said it is rideable but shoud be checked out by cannondale.
    1995 Cannondale F300
    2008 Cannondale CAAD9 5
    2011 Cannondale RZ 120 2
    2004 Mazda RX-8
    2003 Mazda Protege5
  1. Lefty headset/cups/steerer tube movement/play
    By xsanmarco in forum Cannondale
    Last Post: 08-28-2011, 07:53 AM
  2. Anyone riding a small wth a Lefty?
    By 1spd1way in forum Niner Bikes
    Last Post: 05-26-2010, 02:47 AM
  3. Cannondale bikes with lefty in a SMALL = BAD?
    By i3eezenotch in forum Cannondale
    Last Post: 04-15-2008, 05:38 AM
  4. Bipedal Movement vs. By Pedal Movement...
    By ICanDigIt in forum Passion
    Last Post: 06-26-2006, 08:46 PM
  5. Man, the 29" movement is still VERY small
    By pieter in forum 29er Bikes
    Last Post: 02-27-2005, 02:59 PM
