Results 1 to 11 of 11
    Lefty SL oil viscosity
    Hello everybody
    Does anyone know what is original oil weight or viscosity in the Lefty SL ?
    regards
    unemployed team mechanic
    Golden Spectro 85/150
    thanks
    compared to oil used in fox, it's generally 7,5 or 10 W
    what means 85 150 ? 85 W is for car's gearbox ??
    2.5 weight. golden spectro is measured differently.
    2.5 ?!! it's almost water
    thanks for info
    did anyone try with heavier oil ?
    Feb 2005
    AKA 85/125
    Thicker is great if you need a range of adjustment bump, due to a heavier spring.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    A tip I got from the pro motorcycle boys:
    You can mix your own to match your conditions - 50% 5wt + 50% 10wt = 7.5wt.
    Any good moto shop will carry a range of weights.
    Kanonkuglen.dk
    Reputation: lars_kanonkuglen's Avatar
    Hi... check this previous thread out: How I made my Lefty SL run ultra smooth!
    Got the Cannondale fewer - my cycling blog: kanonkuglen.blogspot.com
    thanks for info
    you say 10W, but wich oil factory ?
    I'd steer clear of the SAE viscosity classifications since those are a range.
    Golden Spectro 85/150 is a 9cst to 16cst oil which is pretty heavy and equates to a Fox 1`10W.
    Also viscosity does not blend linearly so mixing 50% 5W + 50% 10W willl not give you 7.5wt but closer to 6.6wt..
    you also need to make some assumptions.
    Spectro has performed best in my Lefty's and I insist on only using that.
    Thanks for the correction Brad
