Results 1 to 7 of 7
    Nor­wegr
    Reputation: Vegard's Avatar
    The lefty remote
    Is there a way to put it on the fork? I just find the handlebar remote annoying.
    Feb 2005
    You need a new damper.
    They are the same damper, but Cannondale in their infinite wisdom, doesn't offer the small, stainless widget needed to go from XLR to PBR, as a small part to purchase.
    Alternately, if you can find a PBR guy that wants XLR, and you have the capacity to totally disassemble the dampers, you have all you need....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Reputation: Flash29r's Avatar
    May 2013
    Could you post a pic of this piece you are referring to? I actually still have my PBR and am running an XLR now. If I can see what you are referring to I may actually try the swap. I looked at it initially when I bought the XLR fork and figured you had to switch out dampers to make it work.
    Feb 2005
    If you remove the PBR knobs, you're looking at the top end of it.
    Two loose ball bearings are parts of it, remove over a good "catch" surface.
    You need to fully disassemble the damper shaft to get to it.
    Don't damage your shaft in the process, you'll be very sad if you do.....
    - FrostyStruthers
    Quote Originally Posted by MendonCycleSmith View Post
    So will his wife.......................................
    Lead by my Lefty............... right down the trail, no brakes.
    Nor­wegr
    Hmm, perhaps it would be simpler to just shorten the hose and put it on the other side of the bar, is there a how-to on that anywhere?
    Feb 2005
    Nope, not that I'm aware of.
    I wouldn't, unless you like mechanical cans of worms......
    - FrostyStruthers
  1. Lefty XLR remote stopped working.
    By eduluke in forum Cannondale
    Last Post: 09-14-2012, 05:30 AM
  2. Replies: 0
    Last Post: 08-13-2012, 08:04 AM
  3. Remote Lockout for Lefty
    By cody_canning in forum Cannondale
    Last Post: 08-13-2012, 07:52 AM
  4. convert a Lefty DLR to a XLR with remote ?!
    By N2B in forum Cannondale
    Last Post: 09-20-2011, 03:50 PM
  5. lefty with sram remote lockout reset...
    By mattmor in forum Cannondale
    Last Post: 03-21-2011, 11:22 AM
