Results 1 to 6 of 6
Thread: Lefty races?
    Lefty races?
    So what would happen if the races on a left sent in in the wrong order?
    Feb 2005
    The world will implode.
    Actually, all kidding aside, asking in an intelligible fashion will go a long way to getting you the answer you seek....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Sorry I thought that it was a genuine question. My bad.
    What I mean is...If I was to dismantle a lefty and during the process the races (inner and outer) where to get muddled up. How bad would it be? Would it be play in the fork? stiff travel? What would happen. What would be the symptoms?
    Feb 2005
    It's a legit question, all good, if you read what you wrote though, you'll see, it's meaning is tough to suss out, now? I gotcha....
    Outers and inners are not easily mixed up, they look different from one another. The outers are identical, all the same, no chance of mix up, but do keep the "used" surface in play, don't flip them around as it will cause some mating issues upon reinstallation.
    The inners may be the same thickness, or may all be different.
    A set of calipers will allow you to play around till your square is "as square" as it can be....
    - FrostyStruthers
    Are I see. That's what you get with beers and iphone predictive text.
    Cheers fella, makes perfect sense. Is the different thicknesses of race down to the machine tolerances when manufactured? I would have thought c'dale would have worked to tighter tolerances rather than botching with various shims.
    Feb 2005
    Quote Originally Posted by sam_roberts30 View Post
    It's more of a way to fine tune things and achieve absolute square. Machining tooling changes over time too. The races are in differences of a thousandth. Not talking big fat variances here.....
    - FrostyStruthers
  1. SPAM: Lefty 29er Wheelset & Lefty (links to ads)
    By SpeedyChix in forum 29er Bikes
    Last Post: 10-15-2012, 01:38 PM
  2. SPAM: Lefty 29er Wheelset & Lefty (links to ads)
    By SpeedyChix in forum 29er Components
    Last Post: 10-15-2012, 01:13 PM
  3. Replies: 0
    Last Post: 01-12-2012, 11:25 PM
  4. Replies: 56
    Last Post: 08-26-2011, 12:43 PM
  5. Planning 2011 races- how much rest between races?
    By Oh-my-tush-a in forum Endurance XC Racing
    Last Post: 02-01-2011, 05:24 PM
