I'm considering having a custom frame built around a Lefty, but have some questions first. Hopefully some of you can help me out with some answers!
1) Where do you find measurements of A-to-C and offset/trail for the different Lefties? How does their offset/trail compare to standard suspension forks, and do you need to design geometry to accommodate any difference?
2) Can anyone give a quick guide to the pros and cons of the different dampers available?
3) How easy is the Lefty to remove from a frame? This is essential for the projected application of a travel bike that will fit in an S&S box.
Thanks in advance for any help!
