Results 1 to 6 of 6
Thread: Lefty Question
    Reputation: mgreen's Avatar
    Lefty Question
    Is this the correct spacing for my shock? I can not remember if it was sitting flush at the top.
    Feb 2005
    It's fine there, or all the way at the top, no worries. Just make sure the bolts are snug, so you know it didn't slip down on it's own
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Reputation: Bubba74's Avatar
    Feb 2007
    Can it be lower?
    Mine has the same clearance as shown above. Can I lower the fork so that the cap is closer to the top mounting arm? I would like to run a shorter stem, and this would definitely help alot.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    You can.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Well I went ahead and moved mine to where it’s flush. By the way, everything was loose. I could not believe it. I'm going to have to watch that. Anyway, I used a 5mm then torque it down to 60 In-Lbs. 60 In-lbs to Ft-Lbs equal 5 Ft-Lbs right? If I remember right, 1 In-Lbs=.08 Ft-Lbs. Well that’s what I torque everything to.
    Well thanks for the info. I have a feeling that’s where the creaking noise was
    coming from.
    Reputation: ccaddy's Avatar
    Don't forget blue Loc Tite on the clamp bolts .
