Results 1 to 35 of 35
Thread: lefty question
    lefty question
    do lefty forks only fit cannondale bikes
    or could i retrofit one to my current ride
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    They are designed to only fit Cannondale frames but you can get adaptors to convert a Lefty to a 1.125" headtube. Your headtube length must not be too tall though. Project 321 makes such adaptors and can probably help you figure out if it can work with your specific frame.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    I just wanna go fast!
    Reputation: bdamschen's Avatar
    ?? isn't the cannondale headtube just a 1.5 headtube?
    Lefty Heaven
    I cant remember the difference, but I know that the Cannondale headtube isn't like other headtubes. The size is slightly different. I read about it on a Cannondale Q & A site.
    I have seen a Scott Ransom running a Lefty on the Weight Weenies site. It has carbon 4 spoke wheels and looks either hot or odd, I cant decide!!
    LA CHÈVRE
    The frames are both compatible with OnePointFive but the Headsets and steerers are not OnePointFive, it's something like 1.57"... You could put a Lefty in a OnePointFive frame with the Cannondale SI headset...
    Good job! Lefty's for all
    Quote Originally Posted by mikedesign
    Dan is right. Project 321 does make an adaptor for 1 1/8" headtubes.
    I've been using one for a couple of months and am EXTREMELY happy with it.
    Project 321 steerer here as well. Made for the Carbon Leftys. Its cheaper than the other steerer because it doesn't come with the clamps, just the steerer tube. On the carbon Leftys you're restricted to a maximum total stack height (headtube, headset, headset cups, spacers, etc...) of 5.417", because the clamps are bonded/rivited to the Lefty fork, unlike the other Leftys where the clamps are bolted on.
    discombobulated SuperModerator
    Jun 2005
    Quote Originally Posted by Dan Gerous
    1.562"
    thats 1 9/16".....
    Quote Originally Posted by CdaleTony
    1.562"
    thats 1 9/16".....
    I think you may have just won the Biggest Cannondale Geek award with that one.
    Reputation: marty_hd's Avatar
    Another shameless P-321 plug
    I have used both Vince's steerer tube (based on Terminauts design) and the P-321 Lefty Adaptor with clamps. The Project 321 adaptor is simple, works and I am pleased with it. Not affiliated with P-321, just a happy customer.
    Cheers,
    Marty
    Hello! im interested on putting a lefty in a 1 1/8" frame, i want to buy the project321 steer tube. I have a 100mm lefty and i want to put this in a L size frame, the steer tube is enough? it fits in all kind of leftys?
    thanks!!!
    Mar 2005
    Lefty on Scott Ransom
    can some body post the photo of it?? coz i went to the website i cudnt find them... thanx!!
    SCALPEL 900 ( Sobe Rep)
    Reputation: pumpkinbiter's Avatar
    Jun 2005
    pics for you
    Jinxkal,
    Marty_hd has posted a picture of the "clamp on" adaptor (above) and here is a pic
    of the "bonded" adaptor. Just let me know if you have any questions.
    sales@project321.com
    Jake
    Jun 2005
    kunzho,
    The answer to your question depends on how the crowns attach to the lefty
    leg. If they clamp on you will need the replacement clamps and steerer. If they
    are bonded you will only need the steerer. However, if they are bonded you may
    have a problem using that lefty on a large frame because the top and bottom crowns
    are a fixed distance apart. So wich style do you have? We can go from there.
    thanks for the input guys a great help
    pace forks can now be gone
    hello! im planning to fit this lefty:
    do you like my bed dress?
    Jun 2005
    Kunzho,
    You need the replacement clamps set and steerer tube. That adaptor is a little
    more expensive 199.99. but it allows you to go up to 6.125" on the stack height.
    It also allows some room to slide the lefty leg up and down to adjust axle to crown
    distance. So there are a couple advantages. Plus the look way cooler than the stock
    crowns. So you shouldn't have any trouble using your lefty. Feel free to give us a call
    if you have anymore questions. Good luck with your conversion!
    Jake - PROJECT321 - 559-906-5253
    doesnt matter now
    just stumped up the readies for a carbon rush frame and lefty carbon
    happy guy
    opss!! why i cant use the same clamps? its to expensive... the fork is going to cost me about 250$ + 199$ plus for the adaptor..., i there's no way to intall these using my clamps? sorry for my english... im spanish!!!
    Another pic of the lefty clamps:
    thanks for the help!
    Your existing clamps won't work because they are designed to clamp around the 1.5" steerer, and you need a 1.125" steerer to fit your headset.
    Hey Jake, why wouldn't the Carbon lefty P321 steerer fit into the clamps on his existing lefty?
    Jun 2005
    Well, it actually will fit. It involves drilling, pressing, riveting, etc.
    I have seen it done but we do not recomend it. I'm really not sure that is even works
    right becuse the stock steerer is pressed into the lower crown and then riveted. I don't know that
    the press dimension is the same as the dimension we hold on our carbon adaptor that gets clamped
    in the bottom crown. Plus (from what I hear) it's just a pain in the a$$. Ask Marty_hd about it!
    Ok! pumpkinbiter! I think i have understood the lesson!
    But i have decide:
    I will buy the p321 steer to tube and i go to my local bike shop to take out the old steer tube and fit the new one with the press. I think if i drill the ribet with the same diameter wont brake nothing.. i think the only problem is to press in and out the steer tube but with a bit of time all fit...
    im not goint to buy the clamps because its to expensive for me, im from spain, and pay 200 + 45(for shipping) its too much, and 90 + 15 for the steer tube is a right price...
    anyone have done it?
    thanks!!!
    Jun 2005
    O.k.
    Kunzho,
    I understand your situation. I can not support your decision to use our adaptors in a way they are not intended. Now that I have said that I will say that I know it has been done successfully so I wish you good luck with the project. Ride Safe! Jake - Project321
    thanks!!! Be sure i will buy your steer tube! the cnc is beauty!!! And better than other on ebay...
    See you!
    See you!
    Jun 2005
    Thanks Kunzho, post some pics when you finish your project.
    Have safe ridings!
    Finally i have finished the project:
    I have the 1 1/8" steer tube in my lefty! I have done all with my hands, its very easy:
    First remove rivet, take out the old 1.5" tube, with a nylon hammer, apply little hits please, put a piece of wood in the tube...
    Then press in the new steer, again with the nylon hammer.
    And now you have to rivet the steer tube in the same clamp's hole. (i havent done yet)
    I have bought the steer tube in: (finally the project321 dont fit on my lefty)
    http://cgi.ebay.com/1-1-8-Steer-tube...QQcmdZViewItem
    Pictures of my lefty:
    Mar 2005
    we wanna see the whole bike!! hehehe .. nice one
    Nice job kunzho,
    GLad to see that it worked out. Apparently you did not have the same degree of problems I had pressing the lower clamp onto the steerer tube.
    Now we need to see the pics of the complete bike.
    Marty
    Feb 2005
    Quote Originally Posted by kunzho
    Why? Can't see any reason why it wouldn't, what am I missing?
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    the project321 steer tube dont fit in my lefty with bonded clamps... the project321 steer tube is designed for cargon lefty clamps (a bit thinner than mines..)
    thanks!!!!
    Feb 2005
    thanks!!!!
    Glad you found something that worked, but FYI, all the clamps are identical as far as inner diameter for the steerer tube/clamp interface. Always has been.....Not too sure why you had a problem. Cheers!
    - FrostyStruthers
    In the carbon lefty's he dimension the part that inserts in the bottom clamp is 12.25mm and in the other lefty's is 18,8mm
    I wanted to buy the p321 steer tube in ebay, when i asked to comcycle to buy the project 321 they said that this dimension was 12.25mm it is designed to fit the bonded lefty clamps witch are .560" (12.25mm).
    they asekd me which lefty planning on using this adaptor on the bonded lefty clamps?
    they say that they have another adaptor for use with the clamp-on lefty clamps.
    Feb 2005
    Ah, got it, you wanted to keep the existing clamps. Now it all makes sense
    - FrostyStruthers
    I finished the bike:
