    Reputation: karlmichael's Avatar
    Lefty PBR air chamber spacer part number
    Can anyone post a link with the correct spacer reducer for the lefty PBR air chamber or tell me how to make one and the correct thickness to get the lower end up my shock to ramp up? im 190 lb and i find im blowing though my travel and i want the bottom end of my travel to resist bottoming out. also does any one know the part number for the updated piston kit?
    my local bike shop has not been able to find them yet and i would like to give them the part numbers so i can get my lefty back on the trails as fast as possible.
    thank you
    karl
    Sweater
    Reputation: Buzzaro's Avatar
    All out of S**** and down to my last F***
    thanks buzzaro. do you know about the spacer that is used to reduce air volume in the shock? i heard it helps the fork feel more progressive on the bottom end of the travel. does it need to be purchased from cannondale? also do you put into the air chamber or does it go on the out side shaft? and if it goes on the out side does it reduce travel?
    thanks karl
    Found the info on instaling the spacer and I found the spacer too. They are old shock elastomers.
