Results 1 to 2 of 2
    Reputation: karlmichael's Avatar
    Lefty PBR 140 and lock out issues
    I just got a new 2011 Lefty PRB 140 from the lbs about 4 weeks ago. i have had to rest the bearings once so far and my issue is with the lock out. i just reset my lefty before my ride and once i got done with my ride i noticed that when i push the lock out button and i go over small bumps i feel a small knock in the fork. kinda like it needs to be reset but i just reset it. is this knock normal with the PBR? or is it a sign that a reset is need ( which i just did? or is it an different issue. the trail i rode has quite a few 1-2 ft drops with a very rough down hill section about 3 miles. i run my air pressure about 20 pounds over for my weight but well under the max psi. i did not bottom out my fork either on this ride.
    any advice?
    karl
    fixed
    My lbs fixed it. An slighly loose air chamber
