    lefty max spv to 29er
    okay I might not have a handle on how to use the search function here, I found a million references saying how simple it is to convert to a 29er but no directions Can some one direct me to a link on the steps to do it.
    thanks ken
    Feb 2005
    There are several threads on various versions of opening, and servicing, or modifying (FFD to TPC, etc) the Max. Find one of those. What you need to do is add a 30mm spacer to the shaft, at a point when you have the spring, and shaft's top end off. Thing is finding spacer material, as Cannondale does not officially offer or recognize 29er Maxes.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Dr Gadget is IN
    Reputation: wadester's Avatar
    Check out the FAQ sticky at the top. Lot's of pics and once your read thru you will find the info you desire. Or at least let you ask more specific Q's.
    Good Luck!
    This isn't a "you're doing it wrong" topic.
    WSS/OSS: Open Source Sealant
    thanks
    Thanks MCS look easy enough. Did you ever try this on your prophet? If so did you like the results?
    thanks ken
