Results 1 to 5 of 5
    Lefty Max bearing migration
    Does the lefty max have the same problem as the dlr2?And is the process the same to reset the bearings?
    The MAX is even easier to reset than the DLR2 because there is no lockout lever to remove.
    Feb 2005
    Best way I've found to handle it is a simple routine. Like once a month, or something like that. Or when you check tire pressure. Super easy, and an even interval allows you to keep track or how fast it happens. I lose about an inch in a month, and just when the front end feels a bit sluggish, 2 minutes later, all back to normal. Bonus is, it takes less slamming, if you do it more frequently
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Reputation: woodsguy's Avatar
    How do you remove the lockout lever?
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Quote Originally Posted by woodsguy
    Check this out!
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
