Results 1 to 7 of 7
    Lefty MAX 140 TPC hydrolic lock after oil change
    Rebuilt my Lefty MAX 140 TPC. Added oil after replacing the o-ring with a quad seal. I cycled the dampener several times, the same with the rebound assembly as it was inserted, to get all of the air out. I filled the dampener with oil so it would ooze out of the bleed hole when the rebound assembly was screwed in. Once togther though I could not cycle the dampener. So, I then removed the bleed screw and pushed in the dampener rod and then installed the bleed screw; I was then able to cycle the shock. But, will this cause air to be sucked in as the fork is cycled? Am I missing something here?
    Feb 2005
    [/LEFT]I'll go out on a big limb and guess that you didn't replace the foam compression compensation element on the compression assembly.
    It's the big black spongy thing on the lower end component.
    If I'm wrong, hand me a hat, I'll enjoy a good lunch
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Yup, the sponge is there. I knew that it was the volume compensating part and important. I tested the fork and it seems to work doing as I mentioned in my post. Hmmmm, is the dampener rod supposed to be out or in when filled and the compression assy threaded in?
    Feb 2005
    Quote Originally Posted by Mascobe View Post
    It has nothing to do with the manner in which you did anything. The foam is saturated. It needs to be replaced. When it can't compress anymore, due to saturation, it locks out the compression circuit.
    - FrostyStruthers
    ... and if we just ...
    Quote Originally Posted by MendonCycleSmith View Post
    I would take that bet also!
    That was exactly what happened with my fork. It was a previous post from MendonCycleSmith on this issue that really saved me from wondering what the heck was wrong. Mine had become saturated and was also breaking down and getting in the oil. My fork is pure magic now!
    Reputation: Rixington43's Avatar
    Jul 2016
    Delete
    Jul 2016
    Quick follow up.
    A member of this forum was kind enough to send me, not only the correct spring for my fork, but a whole bunch of spares he no longer needed due to having PBRd all his Leftys. Suffice to say I have a nice low mileage sheet of foam installed and, having followed instructions on oil changing from here (cycling the rebound rod part way through filling to remove air), I now have a smoothly damped fork with no nasty noises or dead zones.
    Man this forum is a gold mine for a spanner prone newby to the world of Lefty, huge thanks to all involved in its creation.
  1. Lefty won't lock out
    By XC Dawg in forum Shocks and Suspension
    Last Post: 11-24-2009, 10:35 AM
  2. Intermittent lock out after Fox Float 100 RLC oil change
    By rglsr in forum Shocks and Suspension
    Last Post: 10-04-2006, 06:30 AM
  3. Lefty DLR won't lock
    By phillyGTA in forum Cannondale
    Last Post: 10-26-2005, 05:00 AM
  4. After Fox100 RLT oil change lock out no workie
    By EJ_92606 in forum Shocks and Suspension
    Last Post: 08-30-2005, 02:08 PM
  5. Best Way to Lock-Up a Lefty?
    By airw0lf in forum Cannondale
    Last Post: 08-11-2004, 08:24 PM
