Results 1 to 11 of 11
    Reputation: freeriderB's Avatar
    New question here. lefty Max 140 removal...need rebuild
    with all this talk about the Lefty Max...
    Can someone give me the steps of removal from the Prophet? I need to send it in for a rebuild.
    Is it just 3 allen bolts?
    How do you get the crowns to separate from the head tube?
    sorry for the stupid question...but I only know how to remove traditional 1 1/8 forks and headsets.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Carbon? Alloy?
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    lefty removal
    Quote Originally Posted by Dan Gerous
    Carbon? Alloy?
    It's the base model alloy max 140 (rebound only...no spv, no tpc).
    thanks.
    LA CHÈVRE
    1. Take off the brake caliper.
    2. Take off the Lefty top cap.
    3. Loosen the three clamp bolts close to the Lefty's leg.
    4. Slide down the Lefty from the clamps, leaving the clamps on the bike.
    5. Put the top cap back on before sending it away.
    You could also keep the Manual somewhere for future use... Right click and save on your computer somewhere.
    New question here. lefty removal
    thank you sir...
    This will save me a few bucks by doing it myself.
    Do you know if C-dale would accept it directly from me?
    or do they insist I go through a LBS?
    I'm in CT so it would be sweet if I could bypass the LBS....
    LA CHÈVRE
    They usually prefer through a dealer, not sure if directly is even possible... Ask them, say that you are closer to them than to the nearest dealer.
    Bonking ... not feelin' well lefty max 140 removal + search for play
    I called C-dale...I need to go through a dealer.
    Also, I was easily able to remove my lefty in 5 minutes.
    I cleaned it up and began searching for any signs of possible play.
    When I slid the boot down, I noticed the section where the Lefty "screws" together (just like some post stated).
    This was indeed loose, so I hand tightened it, and put the fork back on.
    I was pretty sure that this was the cause of the play in my front end.
    Unfortunately...the play is still there.
    So...is it possible that a damaged rebound cartridge (or some other internal component) will actually cause play????
    If it is not the fork, and not the crowns/headtube bearings....what else could it be!!??
    oh yeah...I believe the hub is fine too.
    You could call this guy to work on your lefty (if its out of warranty)
    http://www.mendoncyclesmith.com/
    I read here he does good work on leftys. Since your east coast anyway, the shipping will probably be about the same.
    Lead by my Lefty............... right down the trail, no brakes.
    Reputation: Dotkom's Avatar
    No way sending in a Lefty Max. This fork is so simple you can do everything at home - although if you want to work on the bearings&races its getting difficult.
    www.swotch.com - Tenerife Island Trail Web
    In the future I'll be putting up a DIY on the Lefty rebuild, using some of my own pics and some of the excellent writeups here.
    This will be sometime in the coming months.
    siv
    siv is offline
    Reputation: siv's Avatar
    Quote Originally Posted by ziscwg
    Absolutely send it to Craig. Dont waste time and money sending it to Cannondale. Ive dealt with him twice not including all the free advice over the phone, he pretty much rules.
