Results 1 to 35 of 35
    Aug 2010
    Bonking ... not feelin' well Lefty Max 140 Rebound Issues
    The rebound adjustment on my lefty max 140 has become nonfunctional. The fork now has no damping (like a pogo stick) and can't be adjusted. Also, the rebound knob does not click like it should. The fork was overhauled a couple of months ago but has ridden fine until this point. Any help with this would be great...I'm out of town right now with no Cannondale dealers around to help out.
    Reputation: alfa75's Avatar
    if you have SPV check air pressure . min 30 max100 PSI. had same problem, no damping and rebound didn't respond!
    pressure was to low.
    Just Ride.
    Reputation: Joel.'s Avatar
    Rebound knob clicks? Mine never has.
    Feb 2005
    The clicks come from a spring with ball bearings on each end, clicking inside the aluminum assembly. Lose a ball, lose clicks. Did you, or someone, take it out all the way at some point?
    As for rebound, have you ever changed the spring on the fork? Same procedure. When you remove the preload adjuster assembly, what's left poking up at you is the rebound push rod. If it's stuck, no rebound. They do get frozen in place, usually water infiltration is the cause.
    If it's still not damping after you get that freed up, it's deeper inside the damper unit, like possibly the flapper valve.....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Aug 2010
    I had the seals on the fork replaced a few months ago (by a local shop) but that is the only time that it has been opened up. After the rebuild it rode great. I haven't replaced the spring or fiddled with any of the internals. I went for a ride last week and it seemed fine, didn't take any hard hits or anything, and now it's busted. Very confusing.
    Reputation: MarkHL's Avatar
    I suspect that your SPV bladder has come off the rebound assembly. The "pogo stick" effect you describe is indicative of this. This is most likely to occur when you have exceeded the recommended SPV pressure.
    You can remove the large nut on the bottom of the fork to check for this.
    It should be attached (by an o'ring) to the bottom of the assembly as shown in this picture. If it is not, you should be dig it out of your fork with your finger and then reattach it to the assembly.
    Caution: Make sure you release the SPV air prior to unscrewing the large nut.
    Aug 2010
    I have the Max TPC not the SPV. Sorry, I should have made that more clear.
    Feb 2005
    Quote Originally Posted by mountaindan
    Very confusing.
    Frozen push rod.
    - FrostyStruthers
    Aug 2010
    Quote Originally Posted by MendonCycleSmith
    Frozen push rod.
    Thanks for the help...looks like I'll have to hold off fixing it for a couple of weeks until I'm back in town with a LBS I trust.
    Feb 2005
    If you're okay with calling yourself a ham fist, that's a good plan. If you can change a tire, or a set of brake pads, you can DIY this, no problemo, in about 10 minutes......
    - FrostyStruthers
    Aug 2010
    What does the repair entail? The only issue is that I don't have a BB wrench...but I'm sure I can find one to borrow.
    Feb 2005
    Awesome! I love shops that diagnose psychically
    BB tool, undo top cap.
    Undo preload rings so spring is loose.
    19mm box wrench under the top cap, look inside the spring to where the preload section terminates, there will be a 9 mm wrench flat there, put one on it.
    Turn the preload section off. Remove the spring. You will see the push rod. If I'm wrong, this will pull out easily. If I'm right, it's stuck. put the 9mm back on the flat, and with a pair of pliers, firmly grasp the push rod, and twist the wrench. If the whole thing won't budge, you need bigger help. They usually come free pretty easily though.
    Light emory cloth clean up, some grease smeared on, and reinsert. It will get caught near the bottom, make sure it's all the way in. You'll feel a slight spring back as you push against the bottom end. That says you're good.
    If your rebound still doesn't work, get back to us.
    - FrostyStruthers
    Aug 2010
    Thanks for the detailed instructions. It looks like the push rod wasn't stuck, it came out easily and after greasing and reassembling I'm still having the same issue. I also noticed that the fork was not measuring the correct extension length. After trying numerous times to reset the bearings I'm still getting a harsh top-out clunk and 700mm max extension. Part of the problem perhaps? Thanks again for the input.
    Feb 2005
    Stuck flapper valve then. Pretty much the only other controlling factor in the rebound circuit. Time for a service it sounds like.
    - FrostyStruthers
    Aug 2010
    That's what I was afraid of...I'll drop it off next week for servicing. Thanks MendonCycleSmith.
    Feb 2005
    FYI? Cannondale no longer supports that fork. If you have a dealer that does them in house, you're all set, and bring them a 6er thanking them for doing so! If they're like most, and ship them out, it won't get worked on. At that point, you'll need to find a service center yourself. They do exist.
    - FrostyStruthers
    Aug 2010
    Perfect. I love how Cannondale touts their system integration and design, but refuses to repair a 4-year-old fork. I thought med-high end bike companies were supposed to stand behind their products? Hopefully the local guys can repair it.
    i have the same going on with my 2 year old lefty RLC110!
    WTF !!! such an expensive fork and discontinued support? too ridiculous how they
    treat their customers!
    Aug 2010
    Quote Originally Posted by alfa75
    I agree. I have been happy with Cannondale up until this point...but if I can't get this thing fixed I'll never support them again and encourage anyone interested buying Cannondale to steer clear. Seriously, why go through the effort of designing and manufacturing high-end components if YOU CAN'T FIX THEM!
    Feb 2005
    I agree. I have been happy with Cannondale up until this point...but if I can't get this thing fixed I'll never support them again and encourage anyone interested buying Cannondale to steer clear. Seriously, why go through the effort of designing and manufacturing high-end components if YOU CAN"T FIX THEM!
    Your fork's issues are caused by Cannondale and Manitou no longer having a relationship.
    That was several years ago that they parted ways.
    The parts party had to end sometime, you know?
    Be glad, Cannondale for their part, still offers all the races, bearings, seals etc, so the telescope, as well and normal function of your fork, can be kept going for years, just the parts they didn't make,they can't source anymore, and they don't fail that often I see tons of them, and they keep on ticking.
    Yours is a simple fix (near as I can tell from the back seat here!). Quite unlikely you'll need any parts. Just a wrench who knows what to look for, and what to do when they find it......
    - FrostyStruthers
    Just ship it to Mendon and be done with it.
    I'm not affiliated with Mendon -- I just know he does good work and knows more about lefty's than most cannondale techs
    Nov 2007
    mendon I'm having the same issue with my lefty max 140. Any advise how to fix the flapper valve myself? anything in particular to look for? Is it a little spring or shim that needs to be bent back?
    Feb 2005
    Not really, as it happens when the nut is overtightened, and bulges out the red plastic throat that all sits on.
    You can try massaging the plastic back down, but really, just pop a PBR damper in and be done, or, get lucky and find a used one that isn't deformed.
    Once they go, they're kinda gone...
    - FrostyStruthers
    Nov 2007
    crisis averted. I got it back together and it feels great. Rebound is consistent throughout the stroke. Before the rebound was only working near top out. didn't really change anything just a full disassembly, new thicker oil and good to go.
    so the PBR internals just drop right in huh? Much of a improvement over FFD? My priorities are small bump compliance.
    Feb 2005
    Not saying anything, but a stuck flapper valve creates a situation where the fork feels good, till you spike a hard hit, then it sticks. Just fair warning....
    Yep, PBR drops right in, and is way more tunable than what the FFD can provide.
    - FrostyStruthers
    I have 3 140 max's, they all now have PBR innards, way nicer, simple to install and easy enough to tune.
    all the cart's came from Mendon.
    Nov 2007
    ^hmm. With the PBR innards the lefty now becomes air sprung, correct?
    Can the travel then be changed using spacers like many air spring systems?
    yes it is now air sprung, I have 2 of the 140's spaced down to 110 for our fat bikes, spacers on the top of the cartridge.
    the air space at the bottom of the fork can tuned to your liking with small spacer "blocks" or synthetic wine corks cut to what ever length you need.
    the cart is oil damped, the fork is air sprung...just to clarify
    Nov 2007
    cool. But does trading the coil in favor of an air spring give up some suppleness? My coil lefty is so good over the little trail chatter that I'd hate to sacrifice that
    Feb 2005
    I loved my coils.
    I love the Solo Aired PBR damper even more.
    - FrostyStruthers
    I switched several years ago and do not recall having any regrets.
    Quote Originally Posted by kinta View Post
    OK, So your saying I need to drink wine before I ride. Well, OK, I'll take one for the team.
    Lead by my Lefty............... right down the trail, no brakes.
    Nov 2007
    anyone know if travel can easily be changed once you switch to the PBR air spring guts? Just with simple spacers?
    Id like to drop down to maybe 120 or 130mm on my max.
    Feb 2005
    Travel reduction, yes, easy. Snap clips on or off.
    Making the fork actually shorter or longer much more involved, requires tools and damper removal etc..
    - FrostyStruthers
