Results 1 to 2 of 2
Thread: Lefty Help
    Wandering not Lost
    Reputation: BThor's Avatar
    Lefty Help
    ok ...bit dense on this subject but wondering if you guys could tell me the:
    Axel to crown measurement and the Offset?
    For a Lefty Speed Carbon SL once it's been taken down from 110mm to 80mm for a 29er?
    Also does reducing the travel on a lefty change the axel to crown length?
    all help would be appreciated
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Axle to crown height: 480mm and the offset or rake is 4.6mm/1.8".
    Reducing the travel doesn't change the geometry so the axle to crown length will not change and that's the point to use it for a 29er, if reducing the travel by 30mm would reduce the axle to crown by 30mm also, your tire would still hit the crown on full compression.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
