Results 1 to 3 of 3
    Reputation: karlmichael's Avatar
    Lefty front hub rebuild???
    I have a prophet 5 with a stock lefty max 140. i have been trying to find out what type of bearings to get to replace the current ones in my lefty hub..anyone have any idea?
    karl
    Here you go.
    lefty front hub bearing size?
    Depending on the quality that you want, you can spend $5 to $50 on each bearing. You will need the Park Tool "SPA-1" to remove your hub cap ... noting that this is a left hand thread, so you will need to turn clockwise to remove the hub cap.
    These are pretty standard size bearings that can be purchased from most bearing shops. You can purchase online from ... http://www.superflycycles.com
    Reputation: amillmtb's Avatar
    Jun 2005
    Check BocaBearings website. In the search put "Mavic," then "Front Hub," then "CrossMax ST(2008) Lefty." Since all of the lefty hubs are the same the bearings should fit (Anyone can verify??) If you arnt looking for the expensive ceramic bearings, go to the LBS, they will be able to order some bearings from CDale.
