Results 1 to 10 of 10
    Reputation: sp3000's Avatar
    Lefty ELO motor works, dosen't lock??
    Hi, went for a ride today hit the ELO button, the red light goes on like usual and I can hear the little motor turn, sounds just like normal, but no lock out at all.
    Do I just need a bleed? or is it something worse.
    Before I get jumped on and told to ditch the ELO I really like it and it has never been a problem since 2002! So I'd really like to get it going again.
    The ELO motor is actually two parts press fit together - a motor and a 'gearbox'. It sounds like the two have become separated in your cartridge.
    They're located in the central shaft and you need to completely dismantle the cartridge to get to them.
    It's happened to mine once since 2002 also. An email to the eightyaid guys uncovered the solution for me.
    Great, thanks Nicholasc2, were there any details in the e-mail from 88+?
    did you fix this yourself? If so how?
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    Yes i fixed it myself.
    (the text entry in this forum really, really sux!)
    The motor and gearbox is located in the shaft and connected to the electronics by wires.
    I can't remember any tricks to get to the gearbox and motor, but when you do they just press fit back together and voila, it works.
    If yolu get stuck during dismantling then just post a pic and I'm sure it'll come back to me.
    Thanks Nicholasc2,
    I didn't have the right tools to get the cartridge out so I took it to a friend at cannondale that did a full service and un-seized the gearbox. He did an awesome job and I'm back! also replaced a bent race!
    Sorry to dig up and old thread, but what tools do I need to get at the motor? I can get to the battery no problem, but I'm stuck beyond this. I can't find any tech articles online that shed any light into Lefty dissections. I'd send the fork to Cannondale, but ah, they're the ones who broke the ELO. If I can get it back together, I'd be stoked.
    Feb 2005
    Quote Originally Posted by dr_rob
    Don't know your issue, but have you tried a fresh seal kit? Once they get "tired" oil weeps past, giving the impression the lockout is dead. New seals? Lock out's back. Not saying that IS the problem, but it's classic for leftys and headshocks, one seal really prevents all the oil movement, and when it gets tired, no lockout....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Fixin' shocks Day & Night
    Reputation: two6labs's Avatar
    Nov 2008
    Quote Originally Posted by MendonCycleSmith
    Yep... Seals first and then motor.... You can bench test the motor while doing the seals. When you take it all apart hold the plunger shaft in you hand and you will see oil ports above the piston. Reconnect the battery and the motor slave( the piece that has the red light on it) press the the lock out button and you will see a brass colored plunger turn down and close the oil port. If this does not happen then you need to inspect the motor. But like Mendon said, always replace seals first.
    dr rob - by 'broke' do you mean the same symptoms as the original poster?
    Can you hear the motor whirring when you push the button?
    I think all I need to service mine is a castle tool, a pin spanner and a whopping great load of patience.
