Results 1 to 7 of 7
    Which Lefty do I have?
    I have recently bought a Lefty which was advertised as a 2005 Lefty Max 140 TPC. When I compare it next to a friends Lefty Max 140 FFD it is definitely shorter in length. I am waiting for a tool to arrive so I can reset the bearing migration and I am hoping this will increase the length. Is there any other way of checking which Lefty I have? I am concerned that I may have been sold a 130mm, although the seller assures me it is from a 2005 Prophet. Is there any way to tell if it is a TPC other than the stickers (which it does not have).
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    What are the top and bottom like? Knobs, dials and such... As for the height, yes, a bearing reset could make it as tall as your friend's if you indeed have a 140 TPC.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Hi Dan, The top is the same as the FFD with rebound adjuster and the bottom is also the same with the large black bolt with small hex bolt.
    Reputation: Bubba74's Avatar
    Feb 2007
    The bottom of the TPC should have a round blue knob for compression adjustment
    Feb 2005
    If you take the top cap off with a pin spanner, (little holes in it's top side) it's a 130.
    If you use a Shimano/Truvativ/FSA/Campy BB tool to remove it (little engagement divots in the outer top edge) it's a 140.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Ok, thanks guys. It appears I have a 140mm Lefty Max FFD. A genuine mistake for which the seller apologises and has offered a refund or reduction in price, so all good. Not sure whether to keep it now or hold out for a TPC or SPV.
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    Quote Originally Posted by andyeez
    I saw a rebound shaft and SPV air chamber on eBay the other day.....
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
