Results 1 to 9 of 9
    Reputation: broomhandle's Avatar
    Lefty DLR Ti Rebuild?
    ok, i think its time to rebuild my 2003 Lefty DLR Ti. its making a "thud" sound now. does anybody have a step by step link? ive looked and cant find one. i swear there was one here. ugh, not looking forward to rebuilding it.
    Feb 2005
    Thud as in, topping out or compressing? Top out just needs a bearing reset. Unfortunately with those, you need the tools to remove the cartridge, and then a reset gauge. The newer forks are very user serviceable as far as reset goes, no special tools.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    topping out a guess. right after it compresses, its like a thunk. my rear shock needs a rebuild to, so i guess its time. so is there no easy way to check the DLR out?
    Feb 2005
    Quote Originally Posted by broomhandle
    unfortunately, due to the age, nope....
    - FrostyStruthers
    fooey.. so like would a local bike shop be able to rebuild it? or is it maybe just needing air or something?
    Feb 2005
    Some shops can, others say they can, but send it to Cannondale, who, based on the age, will most likely recommend replacement. Air won't help, the bearings have migrated, totally fixable, normal, and to be expected. They've just improved the design since that one, so it can be done by the rider, in their garage.
    - FrostyStruthers
    thanks... kinda sucks. so a disposable shock huh? and i have 2 of them... a 2003 and a 2000 DLR... thanks....
    Feb 2005
    Not at all. Quite the contrary actually. Probably the most modular and rebuilable forks out there. Cannondale just did a poor job of instructing shops on how to work on them, and initially made little attempt to offer service on any real scale. The result is a dealer network that is totally un familiar with them, as most have never seen the inside of one, and a Tech room that offers good service, but is overworked, and unable to provide real service to older forks, due to parts being older and the like. There are shops out there that do them, just need to ask around, and find someone.
    - FrostyStruthers
    whats the Air PSI supposed to be set at in the DLR? maybe its a little low...
