Results 1 to 6 of 6
    ARCHQUEST
    Reputation: fjyang's Avatar
    Lefty DLR Fork Removal Tips
    I bought a used Cannondale Jekyll with a lefty and want to remove the fork for servicing but after lossening all the bolts on the dual crown so the strut can slide up and down the double clamps but I still can't get the steer tube to slide out of the head tube. Am I missing something here? Should the steer tube just slide out or I need to tap a little with a hamme which I don't feel comfortable with.
    Any suggestion helps, thanks.
    Just tap it out with a rubber mallet.
    Reputation: CabezaShok's Avatar
    Oct 2007
    Quote Originally Posted by vitaccop
    im in the same boat..... i dont have a bike stand, so is there another safe way to secure the frame whilst hammering the headshok out?
    Feb 2005
    Quote Originally Posted by CabezaShok
    Have a friend hang on, tightly.... And don't forget to hang onto the fork as you're hammering. FWIW, it's generally more than a "tap" too. As long as your mallet is soft faced, beat it with a fair degree of agression
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Reputation: amillmtb's Avatar
    Jun 2005
    For a lefty that is stuck in the head tube, I have found that a soft wood block always does the trick. Place the block on the tube and hit the block, therefore not damaging the tube even if you dont have a soft mallet.
    ARCHQUEST
    Thanks for the advice, I'll give it a try with the wood block, I'm just afraid it might a small pin I have to remove or something which if I force it will caused damage.
