Results 1 to 6 of 6
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    Lefty clamp removal and new installation
    is it possible remove the lower or upper clamp on a Lefty carbon 2010 ?
    i want to install in a frame with a short steerer tube
    distance between clamps is 135mm, normally
    i need instead 110 ( steerer tube is 105 mm + haeadset i guess 5mm , to verify )
    must be installed on a 29er frame
    i do not want to use spacers
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    They are bonded, maybe even riveted, the official answer is no, can't be done... You could try but, at your own risks.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    FIRENZE rulez !!
    yes every clamp has 2 rivets ... drilling they can be removed , i guess.
    and after ?
    LA CHÈVRE
    After, you are screwed... or bonded I should say!
    Unbonding the clamp could be disastrous on the carbon, techniques to break the bonding could (would) probably also break the resin in the carbon...
    FIRENZE rulez !!
    so i must ask for a custom bonding ....
    completely impossible
    LA CHÈVRE
    Just get a 2011 Flash 29er Hi-Mod and call it a day!
