Results 1 to 9 of 9
    WAWE
    Lefty bearing/race clip fell out during damper removal?!
    I just successfully removed the damper from a 2011 Lefty XLR using the proper castle tool. I peeked inside and noticed the upper bearing clip was floating around freely. Will I need to remove the lower in order to reinstall it?
    It appears to be a "race clip"... part KF119.
    It's the right-most piece pictured here...
    If the image doesn't show up, here's the source... http://cgi.ebay.com/Cannondale-Lefty...-/220793122054
    Feb 2005
    That's the "clip clip".
    It sits on top of the other one which is the race clip.
    It's a PITA to get it seated back, but yeah, that's what happens when you pull out the damper. Having the outer race retainer tool helps, as it gives you a nice long tool to get it seated properly again.
    Happy fishing, all the inner race tops need to be inside those slots.....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    WAWE
    Thanks for the quick reply... do I need to remove the lowers/bearings or... spend a couple of hours with chopsticks and a flashlight?
    WAWE
    Oh... and....
    ballbuster
    Reputation: pimpbot's Avatar
    Wups!!
    Feb 2005
    Quote Originally Posted by aosty View Post
    No additional parts removal required.
    - FrostyStruthers
    WAWE
    Quote Originally Posted by MendonCycleSmith View Post
    Thanks... I got it on... looks like it just rests on their and doesn't pop/click in too securely? I can see how it easily falls out with the damper.
    Feb 2005
    Yep, they don't have any sort of device holding them on, except the damper itself.
    - FrostyStruthers
    WAWE
    Mendy, thanks again.... you rock... just making sure.
  1. C-clip removal on XO rear derailleur
    By duder in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2009, 06:19 PM
  2. motion control damper removal Q?
    By blahwtf? in forum Shocks and Suspension
    Last Post: 04-19-2008, 05:10 PM
  3. Replies: 1
    Last Post: 07-24-2007, 08:39 PM
  4. Race Face bearing removal
    By JimboCO in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-09-2005, 08:31 AM
  5. Home-Made Bearing Race Removal Tool
    By jisozaki in forum Tooltime
    Last Post: 03-31-2005, 05:55 AM
