Results 1 to 2 of 2
    Supercutie =O)
    Judge spring rate help
    Hello,
    I Have just bought a new cannondale judge and am trying to dial everything in. I need a new spring and don't know exactly where to start. I'm 220lbs, probably 240 with gear. Riding strictly downhill, mostly at diablo. I was thinking a 650# spring but am just basing that off my buddy ridding a 500# spring on his session 88 and he is 180 lbs. Could anyone help me out? What spring are you running on your judge and how heavy are you. Thanks for the help.
    M1 for sale. let me know if your interested
    the numbers a certain someone from mighty C gave me.
    400 => 210
    450 => 240
    i weigh in at 65kg and run a 300 with a vivid shock - if my memory is correct. Might bump it up to a 350 to firm things up a little as it is on the softer side of things. Hope that helps. I would try the firmer spring first depending on the shock and level of adjustability.
    happy trails
