I've been riding my Jekyll for several years but I've always wondered if I had it setup as good as it can be. The bike is a medium, DLR Lefty, Fox shock, and Panaracer Smoke and Dart tires. I weigh 200lbs with gear and ride mostly XC. I run the fork at 150psi and the shock at 210psi. I usually run the rebound at about halfway on the Lefty. 45psi rear tire 42psi front tire. If anyone is using a similar bike what are you running for a set up? Any suggestions on improvements?? Thanks.
