Results 1 to 10 of 10
    Jun 2010
    Jekyll Sag Indicator
    How does this sag indicator work? Is this pic showing 33-40% sag?
    Jun 2010
    After some experimenting I'm guessing that the indicator above is close to the full travel mark.
    Reputation: fondoo's Avatar
    Sep 2012
    see if this helps. it was pulled from the claymore manual
    http://media.cannondale.com/media/ma...LAYMORE_EN.pdf
    page 8-9
    2013 Cannonale Jekyll 3 M
    Jun 2010
    I like the sag indicator on that claymore. Easier to read. I don't know what my indicator is telling me.
    Reputation: chick0's Avatar
    Buy yourself the updated version of the Jekyll indicator, it gives clear sag and travel readings..
    Qwerty Cycles — Cannondale Jekyll Sag Meter KP188
    Jun 2010
    Will do. In the meantime will someone with the easy to read indicator please measure the distance shown in this picture.
    I make it between 4 and 5mm.
    Sep 2012
    heres my sag indicator on my jekyll
    Jun 2010
    Quote Originally Posted by fondoo View Post
    Is that image saying you hit a 100% of your shock travel on the last ride?
    Sep 2012
    yeah, i need to pump more air into the rear. i was running low to test the ride on my last ride.
  1. Jekyll Sag Indicator
    By perch in forum Cannondale
    Last Post: 11-25-2012, 04:11 PM
  2. Element 70 MSL sag indicator?
    By jmayloo in forum Rocky Mountain
    Last Post: 07-14-2012, 03:48 AM
  3. Can you buy the Pivot sag indicator separately?
    By Magilla_Guerrilla in forum Pivot Cycles
    Last Post: 02-01-2012, 04:34 PM
  4. stuck gear indicator
    By darzsiklista in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-22-2011, 04:46 PM
  5. XT shifter gear indicator
    By mstaszew in forum Shimano
    Last Post: 08-05-2011, 02:53 AM
