Has anyone replaced any off the pivot or linkage bearings on there gen 2 Jekyll's yet ?
I pulled apart the shock pivot section on mine tonight to clean it up and re-grease and have discovered a couple of rough bearings in the front downtube pivot.
I had a look in the manual to see what's needed to go about replacing them, but apart from saying to use the KP169 pivot tools, there is little else instruction. Does an instrution guide for replacing them come with the KP169 tools?
Does anyone know if the bearings on the Jekyll are loctite'd in or just pressed?
Thanks..
Thanks..
