Results 1 to 2 of 2
    \|/ What 60 looks like
    Reputation: GaryS's Avatar
    Jekyll Fox Float Pro Pedal-HELP!
    Okay, I did a search and no joy.
    I got this Cannondale Jekyll 400 a couple of months ago and like it a lot but then my previous bike was a first generation Super V (the one with the carbon fiber swing arm) to which was added a Super Fatty M fork. I just got the Jekyll back from the LBS where it got it’s 30 day checkup and in order to see if they fixed (unbent) the rear derailleur I went riding on the nearby paved bike trail with the youngest son and Mrs. GaryS. This was the first time I have done a long pavement ride (previous single track is how the rear derailleur got bent- I'm an old man and I crash occasionally) and while pedaling away I noticed that I was bobbing up and down a lot. I pulled in behind my fifteen-year-old on the Super V and even when he was trying to leave ol’ dad in the dust, the Super V didn’t seem to be bobbing at all. Now this Jekyll has the Fox Float with “Pro Pedal” which I thought was supposed to eliminate this boinga, boinga, boinga. Could it be I’ve got too much air pressure in the thing (220lbs and I weigh 200)? The instructions are rather vague. I do have the almost ½ inch of sag but should I have more? Man, this is almost as disconcerting as trying to set up a wireless network in my house (don’t ask).
    Oh, when I ride it off a curb the Manitou Axel fork soaks up the bounce like it wasn’t even there but the rear goes “boinga, boinga, boinga”. ARRRRGH!
    Tinker Tailor
    Reputation: Ringer X's Avatar
    try this...
    My Fox pro pedal as well. I have noticed some bob during out of seat mashing uphill or sprinting. I have also eliminated 95% of it with the wheel adjuster and weight to psi match. I started with the wheel adjusted in the middle, about 12 clicks and added the same psi as my weight 180lbs. I have my sag set about .55 in. When you are mashing look down and see if you are bobbing if you are, use the wheel adjuster and turn 5 clicks at a time and try this till you dial in your "happy zone" (due to a lack of official terms). The boinga boinga you are talking about is the fast rebound,dampen it a little and see if that helps. It really does work,we have to play with it a little and find our own zones. Good luck.
  1. How to set up Fox Float 100rlc and Fox Float triad
    By mark747 in forum Shocks and Suspension
    Last Post: 06-13-2004, 07:38 PM
  2. Pro Pedal - SPV for Clydes?
    By Mattman in forum Clydesdales/Tall Riders
    Last Post: 06-11-2004, 05:55 PM
  3. 5 spot with fox AVA pro pedal
    By fastcash in forum Turner
    Last Post: 05-28-2004, 06:19 PM
  4. Fox pro pedal WOW!
    By Bird in forum Shocks and Suspension
    Last Post: 04-28-2004, 12:17 PM
  5. Fox Float vs Fox Float R with Pro Pedal
    By ManBitesDog in forum Shocks and Suspension
    Last Post: 02-27-2004, 11:41 AM
