Results 1 to 3 of 3
    Jekyll bushings gone - but which one is it?
    I have some play in the linkage of my jekyll - it rocks a wee bit when you gently lift the seat up. On all the single pivot bikes I've had - this would indicate the rearmost bushing of the shock needs replacing.
    On the jekyll though, which part of the linkage is it likely to be?
    It's a 2012 jekyll 3 with only a few hundred miles on it - although many of those have been in rough conditions.
    Can you actually identify the movement just by looking carefully at the linakge? I was looking at the bike in the cellar in bad light this morning - if I inspect in good light is that likely to show the source of the movement?
    Reputation: chick0's Avatar
    Have you checked the shock bolts are torqued correctly ? I discovered the same thing once while out on the trail, it turned out to be slightly loose bolts.
    Sweater
    Reputation: Buzzaro's Avatar
    I will place a finger on a pivot and lift the bike, then I can feel the slight movement.
    All out of S**** and down to my last F***
  1. Du bushings
    By dulyebr in forum Shocks and Suspension
    Last Post: 04-16-2012, 03:42 PM
  2. Bushings. Hmm...
    By The Grimmer in forum Downhill - Freeride
    Last Post: 03-24-2012, 02:03 PM
  3. DU bushings - where to buy
    By freeriderB in forum Downhill - Freeride
    Last Post: 01-16-2012, 09:46 AM
  4. bushings
    By tunajuice in forum Rocky Mountain
    Last Post: 11-15-2011, 09:52 PM
  5. Where to buy bushings
    By kjsayers in forum Yeti
    Last Post: 10-30-2011, 09:30 AM
