Results 1 to 3 of 3
    jekyll 1000 front noise??
    I am getting alot of creeking noise from the front end when I am riding. The bike is only a year old. Anyone else run into the same problem and if so what is the fix?? Thanks
    Do you think perhaps the spokes??
    Reputation: Polk's Avatar
    Just start going through everything, cleaning, lubing, and tightening. Process of elimination. If you suspect it's the front wheel, maybe your bike shop will let you put another Lefty wheel on for a spin around the parking lot to see if that takes car of the noise. Keep in mind noises can travel, making them hard to trace. A couple years ago I was tracing a creaking on my Ibis soft tail, which sounded like it was in the headset. Turns out the creaking was a cable ferrule near the seatpost creaking when the soft tail compressed. My 2004 Jekyll just came down with an awful creaking. I started going through everything, and it turned out to be the main pivot. It was not loose, it just felt like creaking. All I did was turn it with a 10mm Allen wrench and it's quiet again.
    thanks I'll do that.
  1. Jekyll 1000, What would you change?
    By Vanu in forum Cannondale
    Last Post: 05-21-2004, 06:25 PM
  2. 2001 Jekyll 1000 with upgrades /or/ 2004 Enduro Expert
    By synkronized23 in forum Bike and Frame discussion
    Last Post: 04-13-2004, 06:00 PM
  3. Cannondale Jekyll 1000
    By roadrunner in forum Cannondale
    Last Post: 04-08-2004, 10:06 AM
  4. 04' Jekyll 1000 suspension set-up?
    By SaddleTramp in forum Cannondale
    Last Post: 03-31-2004, 12:21 AM
  5. Specialized Stumpjumper FSR Pro Disc or Cannondale Jekyll 1000
    By coverthawk in forum Bike and Frame discussion
    Last Post: 03-01-2004, 08:37 PM
