Results 1 to 11 of 11
    Jan 2018
    Increase rotor size Scalpel Si carbon 2
    I want to increase the Shimano rotor from 160mm to 180 or better 203mm size. But i cannot find the right solution with the brake adapter. I already checked the Cannondale documentation, but this is not clear to me.
    My bike is a 2017 Scalpel carbon 2 with Lefty 2.0. On this bike the both rotors are 160mm. The original brake adapter installed, is the KH111. I want to increase the front rotor to 180 or 203mm. Has any one has solved this issue? I think the use of ordinairy spacers js not so idea....
    Jan 2018
    Jan 2009
    Looks like it should be KH130 from the Dr. Cannondale website:
    Adapter Lefty 36 27.5 ; 2.0 29er SuperMax Hub, 180mm Disc
    I can check for sure on my SI-5 when I get it back from the shop...
    But as I read it,
    Supermax Hub: KH111 > KH130
    Standard Hub: KH112 > KH131
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
    Quote Originally Posted by Roys View Post
    pretty simple...any 180 or 203mm PM brake adapter will work..I did it to my Scalpel Si to fit 180mm rotors
    Jan 2018
    Quote Originally Posted by guidodg View Post
    I am gonna try this. Same solution, adapter from 160mm to 203mm.
    Thank you for the reply. These adapters are not easy to find, i ordered this one in France.
    Jan 2009
    Jan 2009
    Quote Originally Posted by J_Westy View Post
    But as I read it,
    I forgot to circle back... my Si5 actually uses a shimano adapter to get to 180mm on what I assume is a KH111 (but I don't see it marked anywhere)
    Shimano Mount Adaptor Front Post to Post | Chain Reaction Cycles
    Those adapters are like the easiest thing to find. Any bike shop could order you any size adapter from 4 or 5 different brands. And any cannondale shop could have got you the 180mm mount for the lefty 2.0. Why do you want 203 rotors on a scalpel si ?
    Quote Originally Posted by scooterman View Post
    My first though upon reading this thread. Not that OP really needs a reason to do whatever they want, but it seems like overkill for a bike that is capable of running a 140 rotor on the rear...
    I find it perfect running a 180 front and 160 rear...203 would be overkill also in my opinion..
    Jan 2009
    To be honest, it's stil a bit confusing...
    This the table from the manual:
    So does one of these work directly with a 180mm rotor on a 2.0 with 55mm offset.
    Or do you always need an adapter?
  1. Scalpel SI Carbon 2 vs Scalpel SE 2
    By kamiller42 in forum Cannondale
    Last Post: 2 Weeks Ago, 06:41 PM
  2. Replies: 6
    Last Post: 01-15-2017, 03:11 PM
  3. chainring size increase
    By shackleton47 in forum Singlespeed
    Last Post: 11-16-2012, 11:52 AM
  4. Replies: 1
    Last Post: 03-05-2012, 06:30 AM
  5. Increase in fork size raises HT angle?
    By arkon11 in forum All Mountain
    Last Post: 04-05-2011, 02:32 PM
