Results 1 to 5 of 5
    Jun 2010
    How to Stem replacement on my Rize?
    I am replacing my stock si stem with a si stem with a little more rise to it.
    Is it hard to do the replacement myself or should I take my bike in to have it done by the "pros"
    I assume I have to remove the handle bars which is easy but I am not sure how to remove the stem, I noticed that it is held in my two bolts but when I loosen them, the stem does become loose, but I can't pull the stem out.
    Any suggestions?
    Steven
    Reputation: jason.R's Avatar
    you need the Ernie tool. you local cannondale dealer will have one.
    Mar 2005
    A rubber faced hammer, that's all I've used and it is fine! Just give it a little whack, it will come out easy
    NEPMCPMBA President
    there's the big cap on the bottom, too....
