Results 1 to 5 of 5
    How to run 2x10 Shmano XT crank on Flash 29er
    Should I use the Press in sleeve adaptor that comes with most cannondale frames (guessing the road ones I have laying around won't work) or should I use this Whee;s Manufacturing adaptor where you press an adaptor into BB30 bearings already in the shell Wheels Manufacturing - BB 30 Shims ?
    *Aluminum Flash frame
    IN the alloy frame you are able to use de original Cannondale adaptor. And the adaptor for the BB30 bearings I think it is a really good idea for save some weight.
    I'm running the Wheels Mfg adapters on my 2010 Flash Alloy frame with Shimano SLX cranks. Can easily convert to a BB30 compatible crankset when the finances allow.
    Attached Thumbnails Attached Thumbnails How to run 2x10 Shmano XT crank on Flash 29er-p1010183.jpg
    '16 Cannondale Scalpel Carbon 2
    '15 Niner SIR 9 SS
    '14 Cannondale F29 Carbon 3
    That looks great jdinsj! Thanks for the info, I never see or hear about Aluminum Flash frames on MTBR but I just ordered a Aluminum frame and Lefty, the 45 gram difference on the Lefty did not seem worth the large difference in money and I'm guessing the difference in the frame is 400-600 grams (not sure). I could just sell this new XT Deore crank and buy a SRAM BB30, but I've had nothing but success with Shimano parts.
    Have you had any kind of creak or problems with this setup? I was worried about all the difference tolerances between the different parts.
    No creaks or problems. I haven't had it apart since the assembly in Feb.'10. Pretty sure there is a shim on the drive side per the mechanic at the LBS. Currently running a SRAM cassette, chain and X9 RD with the SLX crank and it shifts just fine.
    '15 Niner SIR 9 SS
  1. s works crank on a flash 29er 2010 ?!!??!
    By N2B in forum Cannondale
    Last Post: 08-24-2011, 02:18 AM
  2. Crank Choice for Flash 29er Carbon?
    By jimification in forum Cannondale
    Last Post: 07-23-2011, 07:30 AM
  3. Paid Spam - SLX 2x10 drivetrain w/FSA 2x10 crank
    By mwb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-20-2011, 03:19 PM
  4. Chain Catchers for 2X10 Flash 29
    By YB1 in forum Cannondale
    Last Post: 12-03-2010, 02:07 PM
  5. K-force light crank loose on Flash 29er
    By ruanlouw in forum Cannondale
    Last Post: 07-10-2010, 08:22 AM
