Results 1 to 5 of 5
    How much is an 03 Jekyll 600 worth?
    Wondering if I should pick up an 03 Jekyll 600 for $450. I know it is an older bike, but I'm looking for a full suspension bike. Plus it has a lefty, so if nothing else I could swap it to my F5. What do you guys think? a few components have been upgraded but nothing major.
    Dec 2008
    Quote Originally Posted by DereX
    I paid $680 for my '05, so I would say go for it if it's in good shape.
    Reputation: karlmichael's Avatar
    if the lefty works and does not leak or make funny sounds do it
    Feb 2005
    Quote Originally Posted by karlmichael
    Think those came with a Headshock IIRC. Not that it matters, what he said about the fork, either way....
    If it's all in good running order, you should be fine. Take a look, I think those had Coda brakes on them? They worked okay, but pads will be tough to find, and they had a 4 bolt rotor pattern, which means you'll need new wheels if the brakes suck.
    Just a heads up.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Thanks for the heads up I wasnt aware they had 4-bolt rotors.
    I don't plan on doing much riding until spring, should I continue to save and buy something newer or do jekylls still hold their own against newer bikes.?
