Results 1 to 19 of 19
    how do i make my lefty lighter?
    just picked up a used lefty speed carbon. the seller thinks it's an '08.
    it weighs 3.22 lbs without steerer. anything i can do to it to get to the 2.7lb speed carbon sl weight or is cheaper just to buy an SL?
    Santa Cruz Blur XC carbon - lefty carbon SL | GT zaskar pro carbon HT - lefty carbon | Scott CR1 | Look 595
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    You can't get it to weigh as low as the SL without replacing... pretty much every single part. If you wanted a Speed Carbon SL, why didn't you bought a Speed Carbon SL?
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Quote Originally Posted by Dan Gerous
    really, i didn't do my homework. i thought all the speed carbons were the same weight (except for the dampening) so i snatched one up on ebay. i guess construction is different.
    might just hold onto it anyways. got it for a good price (i guess it was an OK price since it wasn't the SL version ). it weighs the same as my fox f80x but should be even stiffer and more plush. as long as it's not HEAVIER.
    Reputation: RiderInTraining's Avatar
    Apr 2005
    A really cheap way to make it lighter would be to let the air out.
    I'm Confused . . . Wait a Minute, No I'm Not . . .
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    replace the 2 bolts with TITANIUM ones
    here mine on purple
    cut in half the frame bumper and glue it to fork
    use zip ties instead plastic clamps
    Attached Thumbnails Attached Thumbnails how do i make my lefty lighter?-020.jpg
    Feb 2007
    Fiorentina!
    FIRENZE rulez !!
    Quote Originally Posted by Epic-o
    Fiorentina!
    passion for soccer passes in cycling too and viceversa
    Have you considered an OPI lower & solo air? that should give you a quarter pound gain, I think.
    Quote Originally Posted by venga venga venga
    Quote Originally Posted by almontebarnes
    i, too, thought that might work but i've been reading that the opi lowers can swap into the SL but, from dan's response, it wouldn't work swapping into my regular speed carbon.
    i ended up getting a 2010 speed sl and will be putting the other lefty on my other MTB.
    May 2005
    drain the oil out like specialized does to achieve 'published' weights
    Kam
    Kam is offline
    A hopped on pop.
    Reputation: Kam's Avatar
    i would suggest just sticking with the way the lefty is now. if you want to lighten \up the front end, get a nice edge wheel built.
    yes, expensive but a new lefty will also be just as much $. and, the weight, stiffness and durability of the edge front wheel combined with the stiffness of the lefty....it is a match made in heaven!
    <img src=http://farm5.static.flickr.com/4011/4314739480_66a77209c1_b.jpg>
    "forget kings...forget hadleys......they all have crap engagement. just run your bike fixed gear." - FoShizzle
    Dec 2008
    What dimensions are the clamp bolts on the 2010 Lefties? If I wanted to change them to titanium bolts, what would I be looking for?
    Can they be found here?
    http://www.chainreactioncycles.com/C...ategoryID=1635
    Keep it Simple Stupid!!!
    Reputation: Steel Freak's Avatar
    That's the thing about Lefty's that sucks , you cant cut off the other leg cause it's already gone. Bummer.
    Who cares how much gas you save, ride your bike to work because it's fun!!!!!!!
    IdontShootPeopleAnyMore
    Reputation: DriveByBikeShooting's Avatar
    Quote Originally Posted by Steel Freak
    sure you can, its called a 'CANNONDALE WHEELIE"
    What mountain bike forum do pirates use? .....
    MTB-arrrrrrrrrrrrrrr
    Good job!
    That's pretty smart that way you get rid of a heavy wheel altogether.
    Just Ride.
    Reputation: Joel.'s Avatar
    Take the boot off and put a tube over it.
    Reputation: amillmtb's Avatar
    Jun 2005
    Quote Originally Posted by Joel.
    Yea, if you want to service it after every ride.
    LA CHÈVRE
    I'm starting a new trend: I changed mine to gain weight!
    Actually, I had forgot to have my Lefty SL serviced during winter (it really had a nasty, muddy, wet season last year, bearings/races need some MendonCycleSmith love) so I put a Lefty Fox Terralogic for now... I think it's my favorite Lefty as far as feel and performance goes. No bob but smooth plush action... It's a fair bit heavier than the SL though.
    i absolutely love terralogic. too bad fox is not "allowed" to make it.
    i'm lovin the lefty
