    How do I make my front tire into 29 inch from 26 inch?
    OK so a few things
    1. Is a 26inch in the back with 29inch in the front a 69er or a 96er?
    2. What must be done to make the front a 29inch tire (I would like a fork with at least 80mm shocks and a Quick Locking System as well)
    3. How much will it cost (I don't nessicarly want top of the line parts, but decent parts that will last and won't break on me)
    4. Can I do it my self? Or is it better to have a mechanic do it? I am pretty good with building and putting stuff together and seeing how it needs to be put on and done.
    Reputation: 2004sahara's Avatar
    You need a fork that can accept 29" rims ($300-700)..and yes its as easy as swapping crown races and swapping forks. RS Reba is the most popular.
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    New fork to suit a 29" wheel.
    New rim, with the correct amount of spoke holes to match your existing hub, if you want to reuse that. New spokes and a wheel build. It might be easier and cheaper to just buy a new 29" front wheel, complete.
    New 29" tyre.
    Less isn't MOAR
    So all i gotta do is jus get 29inch wheel+tire+29inch fork and plug it in without any hiccups? wut bout my disc brakes?
  1. What's the best anti-flat tire 16 inch, and 18 inch?
    By Cycle Maniac in forum Wheels and Tires
    Last Post: 08-30-2009, 07:39 AM
  2. Replies: 24
    Last Post: 05-02-2009, 11:34 AM
  3. 29-inch front tire question (Shiggy!)
    By AOF in forum Wheels and Tires
    Last Post: 02-27-2006, 02:22 PM
  4. 5 inch front 4 inch rear suspension balancing?
    By briwear in forum Shocks and Suspension
    Last Post: 02-24-2006, 05:28 PM
  5. Anybody ride 6 inch front 8 inch back?
    By sbrider_ in forum Downhill - Freeride
    Last Post: 02-20-2004, 07:30 PM
