Results 1 to 16 of 16
    How can I run a 60mm stem with a lefty?
    So I've had my Rize (old 130) model for coming up to 2 years. I would like to keep my Lefty (great fork) but find a way to run a 60 or 70mm stem on it. For two reasons 1) to shorten the reach a bit, it is a little long and places too much weight on my hands 2) to improve the handling (I run 60mm on my all mountain and dh bikes and the difference is massive, even 10mm can make a difference!).
    Am currently running a 90mm XC3 SI stem. Its the XL model, which has a 1" longer head tube than the other models.
    Can it be done?
    What parts do I need?
    btw I don't care if I have to remove the stem to reset bearings, its not a big deal.
    Get a new stem?
    Quote Originally Posted by ssc280
    Get a new stem?
    Cannondale don't make a 60mm XC3 SI stem (integrated stem / steerer), at least not that I know of
    Quote Originally Posted by Zodiac
    I've only ever messed around with the stem on a Rush or Scalpel, I'm really not familiar with the Rize.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    So you have a one piece stem/steerer currently? Just get the separate steerer, then you can find a shorter stem than the XC3 integrated stem/steerer is available in...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    i tried a 80 mm stem in a M size fame
    did not fit : the bar touched fork head
    LA CHÈVRE
    But with a XL and the longer headtube, the Lefty's head should be a bit lower relative to the stem no?
    FIRENZE rulez !!
    but Lefty clamps are in the XL version too ....
    FIRENZE rulez !!
    no , you don't care about stem in the needle bearings reset
    Reputation: brentos's Avatar
    Quote Originally Posted by eliflap
    You do if running a short stem on an XL head tube puts the bars directly over the fork top cap.
    Like Dan said, get the seperate steerer.
    Quote Originally Posted by Dan Gerous
    Yes I have the integrated one piece stem/steerer.
    On the XL the top of the fork is about level with the top of the head tube so I should be able to run a shorter stem with no problem.
    If I get the separate steerer (what part # is this?) who can I get a shorter stem from? Isn't it a strange cannondale lefty size?
    <bump> help!
    bump surely someone can help me understand if this is possible. I can't find any cannondale size steerer stems under 80mm.
    Maybe run it with a Project 321 steerer and a 1.5-to-1.125 headset???...then you could run any normal stem as long as it clears the top of the lefty.
    http://www.project321.com/bikeadapters.php
    http://www.canecreek.com/component-h...browse=tapered
    whatever...
    Jun 2005
    Perhaps you need a smaller frame. Not trying to whiz in your Cheerios, but Cannondale geometry seems to run longer stems than other brands, who use longer top tubes and short stems, at least on their XC/Trail-oriented bikes.
    Regardless, running a really short stem on an XC bike is likely to make the bike handle wonky...it's normal on downhill/big hit bikes, whose geometry is designed for a super shorty stem.
    Reputation: pumpkinbiter's Avatar
    Jun 2005
    <bump> help!
    This would allow you to use any 1.125" stem on the market.
    Attached Thumbnails Attached Thumbnails How can I run a 60mm stem with a lefty?-1.125-cannondale-steerer-installed.jpg
    Jake
    Project321
    877-584-7321
