Results 1 to 2 of 2
    Hope V2 on Prophet 4x team
    I'll about to pull the trigger some V2, are there any intereface issues??????
    teh old 4x team version with the lefty max carbon? if yes: you will likely get problems when using larger rotors than 190mm. the shock boot will get cut by the larger rotors under full compression (especially when hot). iy built a little fender between shockboot and brakerotor but it didnt function well when using more than 130mm of travel.
    CW
